So I am under way with my upgrades. I need to know if these compenents will work together. Not sure if these heads are to big for the stock bore. What you think? What kind of power you think I will make with this?
If your running a stock cubic inch motor the LSX intake and BBK TB are unnecessary. The ZO6 intake and ported factory TB will be more than enough for your set up and also save some $$. I also think the 38 lbs injectors are not needed, 30 lbs will do the trick IMHO
