Clutch Drops To Floor!!!!!!!!
Old Aug 27, 2005 | 07:37 PM
zo6rookie's Avatar
zo6rookie
Default Clutch Drops To Floor!!!!!!!!
I Have A 99 Frc, Does Anybody Have An Idea Why My Clutch Pedal Drops To The Floor When I Accelerate Hard, I Then Have To Pic The Pedal Back Up With My Toe Bit The Problem Seems To Be Getting Worse... Missing Gears Is No Fun The clutch, presure plate and flywheel are new.
Old Aug 27, 2005 | 07:48 PM
Geneus's Avatar
Geneus
Time to consider a replacement.
Old Aug 27, 2005 | 08:38 PM
DRR's Avatar
DRR
Default Clutch Problem
Sounds like the master or slave or both if your clutch, p/p and f/w are new. How new? Try bleeding the system first, hope you got the remote bleeder installed when you did the clutch. DRR
Old Aug 27, 2005 | 09:10 PM
Phil97SVT's Avatar
Phil97SVT
How about you remove the spring from the clutch pedal?
Phil
Old Aug 27, 2005 | 09:55 PM
zo6rookie's Avatar
zo6rookie
Phil
I already tried bleeding the system, cost me $80.00, did not have the remote bleeder installed, the spring I will try tomorrow..
Old Aug 28, 2005 | 08:27 AM
jers98vet's Avatar
jers98vet
Usually when this happens its the slave cyl. When you had the system bled, did the tech notice any wetness ariund the slave?
Jer.
Old Aug 28, 2005 | 09:15 AM
OBSESSHN's Avatar
OBSESSHN
Cruising
I had the same problem on my 97 and when I replaced the clutch assembly I replaced the master and slave. That fixed the problem. You should have replaced the master slave and installed a remote bleeder when you did the clutch. The only problem I have now is I damaged the tranny driving with a bad clutch! So you should get it fixed ASAP!
Old Aug 28, 2005 | 04:04 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Phil
Removing that spring will fix 99% of the clutch pedal to the floor problems.
To Clutch Drops To Floor!!!!!!!!
