Just yesterday I started to get codes P0113 and P1111 and my idle has dropped down around 600 and the car seems to be held back or hesitant not to mention around 4700+ RPM i'm getting a really bad ping/knock. Any particular reason i'm having these issues? I have a GHL catback and Blackwing. No tune as far as I know.THanks!
The links take you to troubleshooting info for the particular codes. As you can see, both codes relate to the IAT sensor. The t/s directions are for a '97. Later models relocated the IAT sensor (from what is described in the directions) to the MAF, but the information is the same. It may be something as simple as a loose/dirty connector or a chafed wire.
BTW, a P0113 code (solid or "hard" failure) always sets a P1111 (intermittent) as well. If you cure one you'll cure them both. GL!
