single gas tank
Old Aug 28, 2005 | 01:05 PM
70 LS1's Avatar
70 LS1
Default single gas tank
Has anyone replaced the dual fuel tanks with a single tank? If so how did you get your fuel gauge to work?
Old Aug 28, 2005 | 03:52 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Why would you want to do this?
Old Aug 28, 2005 | 05:05 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Old Aug 28, 2005 | 06:54 PM
70 LS1's Avatar
70 LS1
I currently have an LS1 engine in my 1970 and would like to use the C5 instrument cluster. Since I only have one fuel sender in my tank, I am trying to see how it would work with the new cluster.
Old Aug 29, 2005 | 12:18 PM
screw991le's Avatar
screw991le
Ahh, nice, any pics?
Sorry, can't help with the tank issue
Old Aug 29, 2005 | 12:23 PM
70 LS1's Avatar
70 LS1
Pictures here: http://temp.corvetteforum.net/c3/70lt1/ls1.shtml
and here: http://home.comcast.net/~baconjb/pictures.html
Old Aug 29, 2005 | 12:38 PM
wwashing's Avatar
wwashing
I believe the C5 only has 1 fuel level sender?
Since the levels are equalized by the inter-tank pump. The fuel level is only measured in one tank.
I think the fuel sender will be the least of your challenges.
Old Aug 29, 2005 | 01:03 PM
C5-BRUCE's Avatar
C5-BRUCE
No, there are two sensors, one in each tank. It would seem logical that the fuel would be balanced between the two tanks, much like an airplane balances fuel in both wings, but it doesn'twork that way.
The right hand tank is drained first keeping the left hand tank "always full". Without a sensor in each tank the computer would never know how much fuel is available.
Old Aug 29, 2005 | 01:45 PM
70 LS1's Avatar
70 LS1
So the signals would be different? That makes it even harder to use one sender. Maybe I could use one sender to sense down to half a tank and the other to sense from half down to empty. That would simulate the two tanks for the computer.
Old Aug 29, 2005 | 01:46 PM
70 LS1's Avatar
70 LS1
Does it say in the Service Manual what the resistance readings would be for the senders?
Old Aug 29, 2005 | 03:07 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Actually fuel always feeds from the left hand tank then return fuel is directed to the right hand tank and a jet pump circulates fuel from the right tank to the left tank to constantly keep the left tank full until the right tank runs empty in which case the only fuel that the jet pump moves to the left tank is return fuel from the rail or fuel line.
I am not going to swear to it right now but I am almost positive that there is only 1 fuel sender and it is located in the left fuel tank.
Old Aug 29, 2005 | 03:15 PM
70 LS1's Avatar
70 LS1
I know for a fact that the PCM has two fuel inputs.
Old Aug 29, 2005 | 03:26 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
I hope my ignorance isn't showing by saying this, but why not put both (assuming there are 2 sensors) in the one tank in your '70?
How do the sensors "know" if they are indeed in one tank or not?
Old Aug 29, 2005 | 03:51 PM
C5-BRUCE's Avatar
C5-BRUCE
YIKES! A "jet pump" and only one fuel sender? No bashing - honest - but I've had FOUR sender/sensors replaced in my 2000 in the right hand tank, and one in the left hand tank. In the interest of technical accuracy I'm republishing below a paper written by GM Engineering as to how the fuel system works. Hope this dispells any further rumors.
The C5 Corvette has two fuel tanks, left and right hand. The left hand tank contains the electric fuel pump that supplies fuel to the engine. The right hand tank has a pump, which transfers fuel from the right tank to the left tank. The pump in the right hand tank has no moving parts and is not really a pump. It is a siphon device that uses fuel pressure from the left hand pump to start a siphon that transfers fuel from the right hand tank to the left hand tank. In order to create this siphon, the fuel line that goes to the engine splits and a small amount of pressure is routed to the right hand tank to start the siphoning. The fuel that is being siphoned is routed through another hose to the left hand tank. If the left hand tank is full, the fuel transfers back to the right hand tank through the large filler tube located at the top of the tanks. The idea is to always keep the left hand tank full whenever there is fuel in the right hand tank. When the fuel gauge reaches a half tank, the right hand tank is empty and the left hand tank is full. Both tanks have a float and sender that measures the fuel level in the tank. These signals go to the Powertrain Control Module (PCM) which interprets the information and sends a signal to the Body Control Module (BCM) which then sends a signal to the fuel gauge in the Instrument Cluster.
Because of the variation in tanks and sending units, the PCM doesn't always read the actual fuel level in the tank. Above or below preset voltage limits, the fuel level is estimated. The voltage limits for each sending unit, right and left, are set to represent "full" and "empty". When one or both tanks have exceeded the preset limits, either "full" or "empty", the system is estimating the actual fuel level. This happens when both tanks are full, gauge is "full"; when the right tank is empty and the left tank is full, "half" on the gauge, or when both tanks are empty, gauge is at "empty".
This estimating strategy and the physical layout of the system results in an unusual fuel gauge characteristic that may be noticeable to some people. When the fuel level is at or near half tank, the right hand tank is empty and the left hand tank is full, so the system is estimating the actual fuel level. Because of the siphoning system, when the car sets [sits] without running, the fuel level equalizes in the two tanks. When the car is first started, the system is actually reading the fuel level in both the right and left hand tanks. After running for several minutes, the fuel in the right hand tank has been transferred to the left hand tank, leaving the right hand tank empty and the left hand tank full. The change in the fuel levels results in the system changing from reading the actual fuel level to estimating the fuel level. This change results in the fuel gauge reading actually indicating more fuel than when the car was first started.
One of the common concerns with the Corvette is the fuel gauge goes to "empty" intermittently. First, lets discuss why this happens. As previously mentioned, the system estimates the fuel level at certain times. When the signal from the left hand sender is above the preset voltage limit, the system estimates the left hand tank fuel level to be full. When the signal from the right hand sender is below the preset voltage limit, the computer estimates the right hand tank fuel level to be empty. In this situation, left tank full and right tank empty, the computer estimates the fuel level and sets that gauge at half tank. Once the fuel level in the left hand tank goes below the preset voltage limit, less than full, the computer begins reading the actual fuel level and setting the gauge accordingly. At this time the computer expects to see the voltage signal from the right hand tank stay below the preset limit that indicates empty. The problem comes from the fact the signal from the right hand tank does not stay below the preset limit. When the computer sees the right hand signal voltage exceed the preset empty limit, it assumes that there is a problem in the fuel transfer system, which is a possibility. When this condition exists, the computer software turns on the Check Gauges light and commands the fuel gauge to the empty position. The logic for this is, if there were a problem with the fuel transfer system and fuel was not being transferred from the right hand tank into the left hand tank, you could have the gauge indicate half tank, when then the left hand tank would be empty and the right hand tank would be full. In this situation you would run out of gas and be walking.
On some Corvettes the situation that is occurring now is the result of the right hand sending unit being attacked by compounds within reformulated gasoline. This condition manifests itself as an erratic voltage signal from the right hand sending unit. In the above scenario, left tank full and right tank empty, gauge at half, the computer looks for the voltage signal from the right hand tank to stay below a preset level. The erratic voltage signal caused by the reformulated gasoline causes the computer to think there is fuel in the right hand tank when there is not. When this happens the computer software turns on the Check Gauges light and commands the fuel gauge to empty. GM has issued a revised computer software, for 1999 through early 2002 models, that raises the right hand preset voltage empty limit to prevent the erratic voltage signal from causing this situation. While it has proven to be an effective solution, it has not corrected the concern in all instances. Another possible solution is to use Techron fuel system cleaner. This has also worked in many, but not all cases.
Old Aug 29, 2005 | 04:22 PM
screw991le's Avatar
screw991le
Old Aug 29, 2005 | 04:37 PM
Dirty Howie's Avatar
Dirty Howie
Excellent Info.
Fuel For Thought....
DH
Old Aug 29, 2005 | 05:32 PM
70 LS1's Avatar
70 LS1
C5-BRUCE: Some good reading for a guy like me. Where did you get a hold of this info?
To single gas tank
Old Aug 29, 2005 | 06:39 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Ok, thats why I didn't want to say for sure that there was only 1 sender, BTW Jet pump is another way to refer to a siphon pump and if you have to buy one of these and ask for a siphon pump the expression your likely to get is
Old Aug 29, 2005 | 06:42 PM
C5-BRUCE's Avatar
C5-BRUCE
It was published elsewhere, and if I tell you where I'd probably have to kill you!
Old Aug 29, 2005 | 06:55 PM
70 LS1's Avatar
70 LS1
The reason I asked is all these tech bulletins people pull out are extremely useful to a guy trying to retrofit C5 systems onto his C3. Just trying to get access to as many as possible.
