C6 Shifter for C5
Old Aug 28, 2005 | 02:38 PM
El Paso Vette's Avatar
El Paso Vette
Default C6 Shifter for C5
Is there an instruction guide or manual to change out a C5 shifter for a C6? I got one from Fred Beans (great service by the way) and I would like to install it myself. So, before I put the car out of commission while I do it, I am trying to find a guide. Any ideas?
Old Aug 28, 2005 | 02:52 PM
Patches's Avatar
Patches
Here's one I did a while back.
http://forums.corvetteforum.com/show...1&forum_id=103
Old Aug 28, 2005 | 03:06 PM
El Paso Vette
Thanks! You guys are great.
Old Aug 28, 2005 | 03:15 PM
El Paso Vette
I presume the neutral adjusting pin is the pin in the front of the shifter? All you do is pull it up once the install is complete?
Old Aug 28, 2005 | 08:38 PM
MagRed_00's Avatar
MagRed_00
Yes, you are correct Now go enjoy the way this car should shift! Also, if you haven't put synthetic tranny fluid in it do that too. That made a world of difference on my 2000 with a B&M shifter.
Old Aug 29, 2005 | 03:37 PM
dunbindun(tov)'s Avatar
dunbindun(tov)
See also my post http://forums.corvetteforum.com/show....php?t=1118835 following my C6 shifter installation. I found a new way to remove the dreaded shift **** key (the worst part of job) and found it easier to remove console cover to do the job as well.
Great mod!
DBD
Old Aug 29, 2005 | 05:08 PM
rws.1's Avatar
rws.1
the devil key is easy to remove.
clamp onto it with a pair of needle nose vice grips (clamp onto the driver and passenger sides)
with your left hand pull up slightly wiggling it to the front and back( like you were a dentist trying to pull out a tooth with a pair of pliers)... simultaneously ...lightly tap the side of the vice grips ( passenger side) with a hammer using your right hand. It took 4 taps of the hammer for mine to pop out.
To C6 Shifter for C5
