Fuel Guage to E
Old Aug 28, 2005 | 03:18 PM
iteachflyin's Avatar
iteachflyin
Default Fuel Guage to E
Last night after I've put 7K additional miles on my newly acquired 2000 coupe, I encountered my first real issue. Funny, just before it happened I was thinking to myself that I've seemed to escape virtually all of the issues I've seen raised on the forum, them bam! HUD and IPC indicated CHECK GUAGES and the fuel guage was on E. Stayed that way for 30 miles home and then for the first half of a short trip this morning. On the way home from my short trip, the fuel guage sprung back to life and is reading correctly. Any ideas on what's going on? Should I even think about asking my Corvette Shop specialist to look into this?
Old Aug 28, 2005 | 03:46 PM
David426's Avatar
David426
A very common problem with these cars is the fuel gauge sending units, which are located in or around the gas tank. They tend to accumulate sulfer deposits rather easily. The result is inacurate readings on your fuel gauge. When I bought my 99 I had this problem. The gauge was fine until I hit 1/2 or 1/4 of a tank, then it would go to empty very quickly. The fix for this problem is Chevron Techron which can be bought at most all automotive stores. Run a bottle through your tank. It may take more than 1 bottle. This usually fixes the problem, if not you will have to get the sending units replaced which is not cheap (labor intensive job). An extended warranty may cover this job depending on the type of warranty. This is most likely your problem. Good luck... There is a post done today just an hour ago that is titled "Fixed Fuel Gauge" Read this post
