micro relays
Old Aug 29, 2005 | 07:38 PM
Mr. Blue's Avatar
Mr. Blue
Default micro relays
The courtesy lights in my 98 stopped working - all of them. The circuit is protected by a fuse (#2) and a micro relay(#42) in the passenger side footwell fuse box. The #2 fuse was blown, so I replaced it, but no joy.
Question - can the micro relays be tested? Also, if they are installed backwards, does it damage them?
Old Aug 30, 2005 | 12:25 PM
Fast one's Avatar
Fast one
Most micro relays are designed so that they will work either way they are plugged in, check the diagram on the relay. Connect the relay coil to a 12 volt battery and hook up a light to the switched contacts as a load then check operation. Small electronic clips from Radio Shack are good for this type of testing. Or you could switch another relay in the car that has the same pinout and see if the circuit works.
