m6 to a4 swap
Old Aug 30, 2005 | 06:39 PM
mitymikec's Avatar
mitymikec
Default m6 to a4 swap
I need to know all that is required for the m6 to a4 swap. i have a ls6 in the car right now and i am looking to put an a4 in it. The car is a 97 and the pcm has been flashed for the ls6.. If i use a pcm from an A4 car will i have to reflash it for a ls6 motor.. If anyone has a link or pics and instructions on how to do that would be great..thanks..
Old Aug 30, 2005 | 07:04 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
You don't need another PCM you just need to have the one you got flashed with the proper program and anyone with LS-1 edit or HPtuner software and extra files can do this for you.
Old Aug 30, 2005 | 08:37 PM
mitymikec's Avatar
mitymikec
ttt
Old Aug 31, 2005 | 12:20 AM
mdhmi's Avatar
mdhmi
I asked the same question recently.
The following thread has some specifics on what is needed to do the swap:
http://forums.corvetteforum.com/show...482&forum_id=1
Mark
Old Aug 31, 2005 | 01:30 AM
gdphillipsvette's Avatar
gdphillipsvette
I just did the A4 to M6 swap and have all the A4 parts:
trans, torque converter, pedal assembly, torque tube, wiring harnesses, and shifter. Also have a 3.15 rear diff (doubt you'll need that). My coupe had 11K miles when I made the swap - no issues, excellent condition.
Let me know if you are interested.
To m6 to a4 swap
