Torx them off!!!!
Old Aug 30, 2005 | 09:33 PM
Irish Whiskey's Avatar
Irish Whiskey
Default Torx them off!!!!
Will I need torx for the calipers or mounting bracket removal?? If so what size??
Old Aug 30, 2005 | 09:52 PM
RoadRebel's Avatar
RoadRebel
I allready told you saturday no Torx on the Vette brakes..
You must be getting senile in your old age!
Phil
Old Aug 30, 2005 | 10:15 PM
QKSLVR Z's Avatar
QKSLVR Z
Active Streak: 90 Days
no Torx.. Socket set an open end wrench should do the trick!
Old Aug 30, 2005 | 10:21 PM
Vette 4 Fun's Avatar
Vette 4 Fun
No TORX, but bring A BIG breaker bar!!!
Old Aug 30, 2005 | 10:31 PM
QKSLVR Z's Avatar
QKSLVR Z
and after, 125 lbs ft to tighten!
Old Aug 31, 2005 | 06:04 AM
leadfoot4's Avatar
leadfoot4
Don't you have the set of Torx bits "just in case"??
Old Aug 31, 2005 | 08:36 AM
2kbluestreak's Avatar
2kbluestreak
The older style GM calipers needed Torx wrenches, which are simialr to Allen wrenches. For the C5 brakes, you need a 15mm open wrench, box wrench or socket for the 2 bolts that mount the calipers to the pins. The pins have to be held with a 16mm or 5/8" open wrench. The caliper mounting brackets require a 21mm socket, 1/2" drive on an 18" breaker bar. You only have to remove the caliper brackets if you are replacing rotors. If you cannot put the C5 on a lift, the front caliper bracket bolts can be loosened if the wheels are turned to move the brakes outwards. On jackstands, it is very difficult to get leverage on the rear caliper bracket bolts. You can lower the torque required by softeneing the Loctite by heating the mounting bosses on the bracket with a propane torch to 60 seconds. Good luck!
Old Aug 31, 2005 | 08:51 AM
Irish Whiskey
Phil
Senility due to life style in the '60's not necessarily to advancing age.
Old Aug 31, 2005 | 11:49 AM
sempi's Avatar
sempi
Default Isn't that the truth?!?
To Torx them off!!!!
