I am still trying to determine if this is even feasable to retrofit the 2001+ Active Handling to my 1970 Corvette. I already have an LS1 engine and C5 rotors, calipers and master cylinder. The issues I am running into are with the Instrument Cluster. I don't want to incorporate the C5 instrument Cluster into my dash, but am not sure as to how this will affect the BCM and EBCM.
With the Instrument Cluster not in the loop I know that I will get code U1096 which is loss of communication with IPC. But I do no know how this will affect the BCM and AH system. Will I still be able to switch modes of traction control without it? I know I won't have the display, but does the IC only display information or does it actually send control signals to the BCM?
What could anyone say? I'm sure that things like weight of the vehicle and other geometric parameters from the C5 configuration went into the computer calculations that govern the active handling responses to input on the C5.
After (if) you get it all hooked up, how will you reprogram it for a C3; using what patrameters.
Just installing AH on a different vehicle sounds dangerous to me without implementing new programming that take the new geometry in account.
I am pretty confident that as long as weight of the vehicle and weight distribution are the same or at least close, then the system should compensate for conditions as designed without reprogramming.
True the system has some parameters programmed into it, but still evaluates inputs from the various sensors i.e. individual wheel speed, lateral acceleration, yaw rate, etc. and compensates with brake pressure and throttle actuation. There has to be self compensating to a certain extent as this is standard on a mass produced car that could vary in weight, tire pressure, etc.
I already have a C5 braking system and C5 sized wheels and tires.
