SLAMMED And 19's?
Old Aug 31, 2005 | 07:15 PM
Nates99ss's Avatar
Nates99ss
Default SLAMMED And 19's?
Few quick questions for those that are lowered and running atleast 19s or bigger. Im looking to run a 19x12 in the back and 18's up front, with me being lowered is it going to require a tub? And will I have a problem in going to 18s up front?
Old Aug 31, 2005 | 07:47 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
i'm doing it
running 295's on the back and it rubs sometimes over real hard bumps
Old Aug 31, 2005 | 08:22 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
I am going to 19 in with 345 in the rear - I need the tub. I think you can run 19s up front too without any modifications...
Old Aug 31, 2005 | 10:48 PM
1 Nasty Z's Avatar
1 Nasty Z
Not slammed but the front bolts are removed and longer bolts are in back. No problems here for two years. Just the normal lowered car scraping.
Old Aug 31, 2005 | 10:50 PM
1 Nasty Z's Avatar
1 Nasty Z
19x11's in the rear, 19x10's in front. Not slammed but the front bolts are removed and longer bolts are in back. No problems here for two years. Just the normal lowered car scraping.
Old Sep 1, 2005 | 12:10 AM
DJMRTS's Avatar
DJMRTS
Me Too!
Old Sep 1, 2005 | 12:19 AM
allaboutdaz's Avatar
allaboutdaz
pics?
Old Sep 1, 2005 | 12:25 AM
Nates99ss's Avatar
Nates99ss
Ive got longer bolts in the rear, and the front bolt has been removed, to give you an idea how lot I sit. The first thing I want are the wheels, if I can do it without a tub...awesome, if not I'll get a tub before
Old Sep 1, 2005 | 12:40 AM
Vortech C5's Avatar
Vortech C5
Slammed on 19x10.5 with 295x35x19 rear and 275x35x18 front...
No rubbing what so ever....
Old Sep 1, 2005 | 12:42 AM
ducatidave's Avatar
ducatidave
Im running 19x11 fronts w/ 305s and 19x13 rear w/ 355. The car lowered some with the T1 suspension kit, I have not slammed it all the way cause the splitter and the rocker kit are already so low.
I didnt tub since I went with a wide body kit. The fronts do rub on the DRM brake ducts under extreme turns. It would have been nice if the front rim were offset with a deeper dish on the outer edge.
Cheers,
-d
Old Sep 1, 2005 | 01:31 AM
Nates99ss's Avatar
Nates99ss
Ive also got Z06 brake ducts, so will that have any effect on the wheels?
Old Sep 1, 2005 | 12:31 PM
toplessvettetherapy's Avatar
toplessvettetherapy
slammed with 20's 0n rear with 285-30-20 and 18's on front with 275-35-18.! See signature for picture.
Old Sep 1, 2005 | 02:10 PM
craig04c5's Avatar
craig04c5
OMG that is one fine looking vert!
Old Sep 1, 2005 | 02:17 PM
allaboutdaz
how much did u lower it?
what did u use?
btw ur car looks real good man
Old Sep 1, 2005 | 02:20 PM
craig04c5's Avatar
craig04c5
More pics please!
Old Sep 1, 2005 | 02:37 PM
vetteamerica's Avatar
vetteamerica
I am lowered with new bolts in the rear fronts turned down all the way.
19 x 11 in the rear and 18 x 9.5 front with ZO6 ducts and no problems at all.
Old Sep 1, 2005 | 03:10 PM
Nates99ss's Avatar
Nates99ss
Awesome thats what I like to hear, please post pics if anyone has some
To SLAMMED And 19's?
Old Sep 1, 2005 | 03:21 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
St. Jude Donor '06-'10, '13
my car is not slammed by any means, but lowered on stock bolts all the way with no cut bushings..dropped about 1 inch. I am running 19x10 in the front with 275's and 19x11 in the rear with 295, no issues so far.
here are some pics
Old Sep 1, 2005 | 03:23 PM
FrankTank's Avatar
FrankTank
CI 7-8-9-11 Veteran
I would not feel comfortable going any lower.
Old Sep 1, 2005 | 03:30 PM
allaboutdaz
how is the ride??
any more pics??
was alignment needed?
