Cam Identification
Old Sep 2, 2005 | 04:09 PM
vetpet's Avatar
vetpet
Default Cam Identification
I've got the following numbers off the back of an LS1/LS6 cam but have no idea who makes it.
LS1 / 3717 / 3764 HR11 T1793 2870A CC
Can anyone help me identify it?
Old Sep 2, 2005 | 06:30 PM
Greg_E's Avatar
Greg_E
That look like a Comp cam. 3717 is a 228 * @ .050" duration .571" lift @ 1.7 rocker ratio. LS1 XR lobe
I didn't see the other lobe listed in Comps online catalog.
It looks like your missing a number for the lobe separation angle.
It should be HR 11#. HR112= 112 LSA etc.You can check yourself in the online catalog. If you don't find what you need, give them a call or email the numbers off the cam. They can probably identify it for you.
Old Sep 2, 2005 | 06:32 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
100%.. I dont see the other number listed either... you sure thats all of them?
steve
Old Sep 3, 2005 | 08:48 PM
vetpet's Avatar
vetpet
Thanks guys. Those are all of the numbers that were on the cam. I'll do as you suggested and give Comps a call. This cam might be a bit too big based on your information so I want to be sure before comitting to using it. I appreciate your responses.
To Cam Identification
