LG header install question
Old Sep 3, 2005 | 02:42 AM
Cscokd's Avatar
Cscokd
Default LG header install question
Well, I finally decided to get started on my header install tonight so I can finish up tomorrow. When I removed my exhaust pipes from headers to the rear flanges, I noticed that the rear O2 sensors were crossed i.e. passenger side sensor plugged into harness on driver's side and so on. This has never been apart since new. Anybody know if that would have made any difference?
John
Old Sep 3, 2005 | 05:27 AM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
As long as the car is running correctly I don't think it would be a problem. Now on the LG's they must be on the proper side.
http://www.vetteweb.com/tech/0501vet_lgpipes/
Old Sep 3, 2005 | 08:27 AM
Mike04's Avatar
Mike04
Here is another site.
http://ls1howto.com/
Old Sep 3, 2005 | 08:37 AM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
John
The rear sensor harnesses DO cross.
The front sensor harnesses do not....make sure they don't when you get to connecting the front sensors.
Due to the orientation of the sensors on LG headers, many people make this mistake.
Connect the left harness to the left sensor, right harness to right sensor.
Unless, they changed the design, I don't think the LG system uses rear sensors, just the front 2, so it's a non-issue for you anyways.
Old Sep 3, 2005 | 12:30 PM
Cscokd's Avatar
Cscokd
ok thanks guys...I just thought it was a little odd that the rear O2 sensors on the stock setup crossed sides.
John
To LG header install question
