Changing A/C Compressor...?
Old Sep 3, 2005 | 08:07 AM
OkeeGuy's Avatar
OkeeGuy
Default Changing A/C Compressor...?
how hard of a job is it?
Old Sep 3, 2005 | 08:43 AM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
The service manual says that you need to remove the radiator and slide the compressor forward and up, but I did it with the radiator in place. I got mine out by removing the exhaust manifold and sliding the compressor back toward the firewall then up and out the top of the car.
It's not all that hard but it does take a bit of time since you have to recover the R134a, remove the hoses, then pull a vacum on the new compressor and then recharge the system.
Tom
Old Sep 24, 2005 | 07:54 PM
Jedster's Avatar
Jedster
Tom
TCW
Do you hange the condensor when you changed the compressor,
Also did you change the pilot tube,
I need to change my compressor too, what all is need in parts?
J
Old Sep 25, 2005 | 08:29 AM
TCW's Avatar
TCW
There's no need to change the condenser but you should use a new pilot tube and ring seals.
I think the seals come with the new compressor.
Tom
Old Sep 25, 2005 | 10:59 AM
Z06ufgrad2002's Avatar
Z06ufgrad2002
If your compressor went bad, I would highly recc. you also change the accumulator/dryer and the orifice tube screen. As these can get clogged by tiny metal shaving from the failed compresor. Also don't forget to add the correct amount to refrig. oil to the new parts.
Old Sep 25, 2005 | 11:04 AM
Jedster's Avatar
Jedster
I have also read online that the condensor should be changed also because of small Teflon particlesget clogged in it, and they can not be flushed out of the condensor,
Does anyone know if thats true?
I am looking at changing:
A/c compressor
Orifice tube
Accumulator
Condensor
Do I need all if the hoses too?
Accumulator hose
Evap tube front and rear
THANKS !
J
Old Sep 25, 2005 | 11:36 AM
jjcslynn's Avatar
jjcslynn
I changed mine by just removing the right exhaust manifold. I did mine on a lift, it made it much easier.
To Changing A/C Compressor...?
