A/C help!
Old Sep 3, 2005 | 09:07 PM
ROD BROWN's Avatar
ROD BROWN
Default A/C help!
My car gets cold on the passengers side,but the drivers side is warm.Any suggestions to balancing it out?(Cold air on both sides).
Old Sep 3, 2005 | 09:26 PM
JR_VETTE's Avatar
JR_VETTE
Mid-TN Events Coordinator
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Common problem. If you have disconnected the battery recently, or it has died, try disconnecting the battery and reconnecting it. It will force the A/C doors to go through a re-calibration. There is also a fuse pull method, but that never worked for me.
Old Sep 4, 2005 | 06:53 AM
ronwc's Avatar
ronwc
Needs freon -
Old Sep 4, 2005 | 09:16 AM
Blow Torch's Avatar
Blow Torch
Originally Posted by ronwc
Needs freon -
My wifes car had the exact same symptoms; We tried pulling fuses, disconnecting battery etc. I took it to a trusted tech, and he found a small leak at the back of the compressor (seal) FIxed it, charged it up and it's cold as ICE!!
Old Sep 4, 2005 | 09:32 AM
JR_VETTE's Avatar
JR_VETTE
Do not add freon until you have checked the codes, and additionally pulled the battery cable. I could find numorous posts like this one. Here's one from just 3 days ago.
http://forums.corvetteforum.com/show....php?t=1176279
As I said, this is a common problem. Try the cable idea first.
Old Sep 4, 2005 | 12:52 PM
ROD BROWN's Avatar
ROD BROWN
Default Freon??
Needs freon -
I would think if my car needed Freon,neither side would be cold,but the right side is like an ice box(younger generation don't know about such things),right side is like a Sauna.I disconnected the battery and I am waiting 5-10 mins.,and I will hook up the battery and see what happens.I guess I will have to reset the Radio,the fobs and let my car relearn all the goodies.hee Hee ho ho its off to the garage I go.Talley Ho!
Old Sep 4, 2005 | 01:38 PM
JR_VETTE's Avatar
JR_VETTE
The cool thing is, your radio and fobs won't need to be reprogrammed! Don't know how, but they will retain the settings. Let us know if this works for you.
Old Sep 4, 2005 | 01:53 PM
ROD BROWN's Avatar
ROD BROWN
Default Its true
Well,the air is COLD.Thanks to all who helped me to cool off.I followed your instuctions and I now have Cold air.I saved a trip to the Wheeler and Dealership,and who knows how many pesos.
Old Sep 4, 2005 | 02:36 PM
JR_VETTE's Avatar
JR_VETTE
I wonder over the years how many dealerships have ripped off us Vette owners on this problem.
Old Sep 5, 2005 | 08:29 PM
bdarbo's Avatar
bdarbo
4th Gear
Had same problem and tried disconnect and it worked, thanks, had planned on taking it to the dealer next Friday!! Bill Darby, Arkansas
Old Sep 5, 2005 | 09:06 PM
JR_VETTE's Avatar
JR_VETTE
To A/C help!
