Corsa Exhaust install question
Old Sep 9, 2005 | 07:14 PM
LS7's Avatar
LS7
Default Corsa Exhaust install question
I'm planning on installing the Corsa Tiger Shark Touring Exhaust on my 2000' C5 and would like to know if this is something that I can do by myself?
I have a 4 Post Lift in the garage. It looks like all I have to do is unbolt the exhaust on both sides from in front of the rear and slip them out of the rubber bushings behind the rear bumper. Then just reverse the process for the install.
Any tricks I should know about or any suggestions would be greatly appreciated.
Old Sep 9, 2005 | 08:15 PM
Corellian Vette's Avatar
Corellian Vette
Its not hard.You can do it yourself. Corsa installed like 80 systems at corvettes at carlise on the fairgrounds with a4 post lift. Just take your time lining everything up.
Old Sep 9, 2005 | 10:43 PM
Ron71's Avatar
Ron71
You will want to remove the two bolts and the the two nuts that hold the rear sway bar, and let it swing down out of the way. This will give you more room to manuever the old exhaust out of the way in one piece. if you are not concerned about the stock exhaust, a lot of members have cut them to make removal easier. The new exhaust conisists of several pieces that bolt together so it is a lot easier to put on than to get the old one out.
Old Sep 10, 2005 | 08:18 AM
tjw's Avatar
tjw
If you don't want to cut the old exhaust, you will have to remove the sway bar to get the passenger side off. Some people have had trouble getting the sway bar bolts back in after the fact due to poor tapping from GM. Just something to be aware of.
Old Sep 10, 2005 | 08:35 AM
Mike04's Avatar
Mike04
Easy job with a lift
Old Sep 10, 2005 | 12:05 PM
LS7's Avatar
LS7
Thanks everyone.
I think I'll just cut the old exhaust b/c I'm not going to keep it and I don't want to mess with the sway bar bolts.
Old Sep 11, 2005 | 07:35 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
To Corsa Exhaust install question
