"Service Column Lock" on the DIC?
Old Sep 10, 2005 | 11:33 AM
dady24's Avatar
dady24
Default "Service Column Lock" on the DIC?
I have a 2001 Z06.
A couple of weeks ago I was parked w/my flashers on for a while. The battery was almost dead, It barely started. When it did the Steering wheel was locked up. I let it run for a little while to charge. When I restarted it the steering wheel unlocked but I still get the "Service column lock" on the DIC. Everytime that I start it I get the same message on the DIC. I have no problem driving it.
Is there some way of reseting the DIC or is there something that needs to be replaced or fixed?
Old Sep 10, 2005 | 11:46 AM
TEXHAWK0's Avatar
TEXHAWK0
Originally Posted by dady24
I have a 2001 Z06.
Read the sticky note at the top of the TECH page.
I think it says that if you pull the #23 fuse in the driver's side footwell, wait a few seconds, then replace the fuse, it should reset the BCM. If you still have problems, make sure the #25 fuse in the driver's side footwell fuse compartment, is good.
Old Sep 10, 2005 | 11:56 AM
dady24's Avatar
dady24
Thanks I'll try that today...
To "Service Column Lock" on the DIC?
