when do you need to fly cut pistons
Old Sep 10, 2005 | 10:05 PM
vettes4fun's Avatar
vettes4fun
Default when do you need to fly cut pistons
I'm looking at installing a cam with a 595/608 lift in a stock motor (lower end) upper as had work done to it. Do I need to have the pistons fly cut are will the engine handle this cam without a problem. I'm running 918 comp springs, Comp said they are good up to 600 lift but I heard people go up to 620 lift it this true. Are should I stay with a little smaller cam Like a LGM X1
Old Sep 10, 2005 | 11:01 PM
rwj383's Avatar
rwj383
If the heads are not milled at all and a stock thick head gasket, you will be fine with that lift cam as long as LSA not tighter than 112, no more than +/- 4* advance/retard ground into the cam, and you install it straight up. You 'should' be ok with the 918 spring, too, but if you have $400 laying around then get the CC921 dual spring kit and install those instead.
Robert
www.gen3motorsports.com
