Codes Codes Codes...
Old Sep 11, 2005 | 04:50 PM
Mikelly's Avatar
Mikelly
Default Codes Codes Codes...
Codes codes codes...
Man I pulled 27 codes from my car today... many of them I'm sure have been there for many many months... Was able to get all of them to clear except two, and then drove it and got TWO more to show back up...
The existing units I couldn't get to clear first:
A6 SCM - B2606 HC
A6 SCM - B2860 HC
After driving the car and turning it off, the B2606 finally cleared, but the B2860 HC remained and will not clear.
During the drive the code C1287 kicked again and the dreaded "Active Handling required Service/ Service Vehicle Soon" code popped up on the DIC. I've gone over everything and still can't get it to clear and stay gone... Wondering what I damaged when I pulled the drivetrain and zip tied the steering rack and ABS block up to the body of the car...
While the car was idling and running in the garage I was cycling the A/C on and off, and I noticed the idle changed when it was off, and the car ran much worse, so I'd cycle it on and off until I got another code (too less than 2 minutes) which was P0134... This is for the left bank 02 Sensors... Wonder if I damaged a sensor when the motor went boom???
To refresh memories, This is the new motor we installed a few weeks back after I had the previous LS1 go boom at VIR during an HPDE. The new motor is a forged bottom end Ls1 based w/ 2.02/1.57 ported heads and a T224 114lsa cam setup... Running LGM headers, Z06 intake and injectors, and running 02 simms on the back two ports.
Ideas Guys???
Mike
Old Sep 11, 2005 | 06:15 PM
tv7son's Avatar
tv7son
B2860=Telescope sensor shorted to open (Steering collumn)
C1287=steering sensor rate/analog malfunction
You problems appear to be in the steering collumn. The steering sensor can be callibrated to center.
P0134 HO2S Circuit Insufficient Activity Bank 1 Sensor 1
http://www.obdii.com/codes.asp
This will help you if want to look up your codes.
I hope this helps.
SFS
Old Sep 12, 2005 | 06:12 AM
Mikelly's Avatar
Mikelly
Thanks. I actually have the shop manuals and was looking the codes up last night... Trying to sort out how to re-calibrate the steering wheel speed sensor now...
Any ideas???
Mike
To Codes Codes Codes...
