Will these tires fit?
Old Sep 13, 2005 | 11:42 AM
aTX427
Guest
Posts: n/a
Default Will these tires fit?
Does anyone know if the 345/30/19 will fit on a standard 11" rim without sticking out or rubbing? They call for a 12" rim, but I had 315/30/18's on my stock z06 wheels, which call for 11" minimum width wheels.
Old Sep 13, 2005 | 01:01 PM
Face's Avatar
Face
I'd go by the manufacture's recommendations.
Old Sep 13, 2005 | 01:37 PM
BlueDragon's Avatar
BlueDragon
Sure, you can get them on the rim. but that ain't the question, you will be running them for looks as outside the Manuf. requirements the performance and wear of the tire drop significantly!
Old Sep 13, 2005 | 02:49 PM
aTX427
Guest
Posts: n/a
running them pretty much for looks. my main concern is rubbing and having them stick outside the wheel wells. The 315's on the stock 10.5" wheels had a minor bulge to the sidewall, but I liked how they looked better than the 295's on my 11" wheels. They have the appearance that the wheel is wider than the tire.
To Will these tires fit?
