How to flush out a diff
Old Sep 13, 2005 | 12:06 PM
sprinter's Avatar
sprinter
Default How to flush out a diff
I bought a new 3.90 diff off a forum member but it had been sitting around for a while in his garage and has some dirt and contamination inside. How should I flush it out? My current options are:
1. Use Kerosene and pour it through the diff
2. Use a mixture of 50/50 kerosene and oil and pour it through the diff
3. Clean it up as best as possible and install it. Then change the diff fluid after 10 and 50miles.
Note that this diff has new gears in it.
Old Sep 13, 2005 | 02:01 PM
sprinter's Avatar
sprinter
Anyone???
Old Sep 13, 2005 | 02:27 PM
sams96's Avatar
sams96
I would go to pep boys they have a cleaner for electrical parts cleaner. I have used this cleaner on heads before and the oil just comes right off. Also dries by air within seconds and leaves no residue.
Old Sep 13, 2005 | 03:05 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
Well.. You could just flush it with fresh oil... til its clean.. then change the oil after like 100 miles or so.
The Kerosene 50/50 mix might be overkill.. and I dont know if it will have any effect on the posi-internals..
Old Sep 13, 2005 | 03:32 PM
c3andc5's Avatar
c3andc5
I use brake parts cleaner on my Jeep gear boxes and it works great. Comes in spray cans and is available at any auto parts store.
Old Sep 13, 2005 | 03:35 PM
FixedRoof's Avatar
FixedRoof
Yeah.. BPC is awesome! I dont know why I didnt think of it... we use it on everything. I rebuilt a 4.3 Chevy not long ago and cleaned out the entire block with it... we used a TON of it cleaning on my heads/cam swap..
Old Sep 13, 2005 | 04:36 PM
sprinter's Avatar
sprinter
Ok... it sounds like the consensus is brake parts cleaner. I will go get some this afternoon. Thanks guys!
To How to flush out a diff
