LAPD bleeder questions
Old Sep 13, 2005 | 07:06 PM
killaz's Avatar
killaz
Default LAPD bleeder questions
I got the LAPD bleeder for when i do the clutch install. Does this just hook up to the slave? And do you bleed it just the same as when you do brakes? Any info or tips i should look for?
Old Sep 13, 2005 | 07:26 PM
FixedRoof's Avatar
FixedRoof
Cruise-In VI Veteran
It will add a remote bleeder line to the slave. Bleeds very similar to the brakes. It will allow you to bleed the clutch without taking stuff apart unde the car.
steve
Old Sep 13, 2005 | 07:36 PM
Patches's Avatar
Patches
Stock slave
Slave with new bleeder
Old Sep 13, 2005 | 08:19 PM
Mikelly's Avatar
Mikelly
I just installed mine, and I'm gonna install a speed bleeder on the end to aid in one-person bleeding. Also, After I installed mine, the system wouldn't bleed with the little rubber cup in the Clutch master.
Mike
Old Sep 13, 2005 | 10:08 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
I recommend cover the aeroquip line with rubber as is passed the fuel line. There have been several cases of chaffed through fuel lines and fires for those that route the clutch bleeder extender line against the fuel line.
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 13, 2005 | 10:27 PM
Patches's Avatar
Patches
Good suggestion, subdriver. It'd be easy enough to retrofit a thin rubber tube over the line by finding one you can cut to length and slide over the braided line from the remote engine bay end.
Old Sep 14, 2005 | 06:06 AM
Mikelly's Avatar
Mikelly
I found the line to be so short that I just routed it next to the braded slave to master line, and let it hang down under the car. It doesn't hang below any of the suspension, so it won't get "hit", but isn't in the engine bay either. I normally bleed everything when I have it in the air on the lift.
Good tip on the fuel line issue though...
Mike
To LAPD bleeder questions
