Codes 2578 and 2583
2578-RF Turn Signal Monitor Circuit (Short to Voltage)
2583-LF Turn Signal Monitor Circuit (Short to Voltage)
Just curious if anyone else has had this problem and hopefully knows of a fix.
I've had 2 or 3 instances where I tried to use my turn signals (signaling lane changes) and they wouldn't work. Then, a few minutes later, they started working again...all without restarting the car or anything.
Thanks for any help!
-JP
-JP
Does your hazard switch work properly? If it does then you likely have an issue with your multi-function switch. Relatively common problem. Check your hazard switch and let us know...
Also, I'm assuming you've checked your bulbs to make sure they're okay? Unlikely for both of them to go out at the same time but you never know...
