Yes the slave does come wiith a throw out berring. Too bad you arn't around chicago because I have a new slave and pilot berring lying around. My texstrilla clutch came with new ones after i already baught them.
If i was to upgrade to the '02-'04 Z06 clutch, flywheel, PP, and Slave Cylinder, can i use a '97 pilot bearing or do i have to upgrade that too?
Never mind on the pilot bearing i found the part numbers for both the C5 and Z06 and the part numbers are the same....so i guess it doesn't matter which one i get.
Which old timer trick? Can you pack the cavity with grease and pound on a socket or dowel to hydraulicly pump out the bearing?
No, you can not do this, you must use a puller but it comes out pretty easy.
Be sure to order the slave/throwout bearing assembly. It is possible to order the slave without the bearing. I recommend calling Tom at Carolina clutch.
