The new bullet is coming....
Shortblock:
LS6 Block Bored 3.905
Line Honed
ARP studs top, bottom, and rods
Katech Main caps
Clevite moly coated rod and main bearings
Scat 6.125" H Beam rods
Lightened LS1 Crank
Diamond custom one off pistons Coated skirts and domes
Lunati Solid Lifters
Top end:
ET Performance 225cc heads brand new castings
- Thermal Coated Exhaust valves and Moly coated springs
Comp 999 Springs
25x-26x custom solid roller .650-.700 lift
Jesel J2k Rockers
Comp Cams Pushrods
Cometic .045 3.910 gaskets
42# injectors
Fast 90mm Intake ported
NW 90mm TB
Power Adder:
Nitrous Express/ECS custom one off direct port 300 - 400 shot
ECS Standalone fuel system
Tuning:
Our custom SD tune
I am building 2 of these motors, one for my 6 speed and another for an automatic and we're hoping this will show the potiential of a nice street motor.
Phil
Phil
HAha, sounds mega fun!!
Any idea when your E.T. heads will show up? Are you going to have flowed again?
Instead of the 225cc 11 degree heads we're moving to a set of 240cc 11 degree heads which should flow close to 350cfm @ .675 lift and about 15cfm more across the board on the bottom end. Cam lift is going to be kept around .680 on a mid 250s duration solid roller.
