dynatech header install
Old Sep 16, 2005 | 08:35 PM
DPG's Avatar
DPG
St. Jude Donor '06
Default dynatech header install
For you guys who have done this, how did you get the driver side header in. I am having a hude dilema right now..Thanks in advance
Dave
Old Sep 16, 2005 | 10:12 PM
killaz's Avatar
killaz
It is kindof tuff. I removed the coil pacs and the altinator. Then you need to have the car at least 24" off the ground. Then push it in from the bottom. The header will run in to a little tab on the block, i have heard of people trimming this off but it is not nessessary, i did it, you just need to hit the exact angle and puch hard. Dont worry you wont damage the header they are very stout.
Old Sep 16, 2005 | 10:19 PM
tiojames's Avatar
tiojames
Default Header install
Loosen the motor mount bolts-do not take them out- jack up the motor a little bit-slides right in.
Old Sep 16, 2005 | 10:43 PM
Rex99Coupe's Avatar
Rex99Coupe
I didn't loosen the motor mount, just jacked up motor 1/2", with 2x4 under bell housing. Found this idea in LS1HOWTO.com. Drivers side was easy on my install using this tip. Passenger side was more difficult because I had to pry the Air Condt. line out of the way, would have been easier with help.
Good Luck!
Old Sep 17, 2005 | 01:00 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i've done 3 dynatech installs and never needed to jack the motor, if it takes longer than 2 minutes to get the header in place send me a pm; i saw the tab off the block for the f-bodies, didn't need to on the c5's; also remove the ground strap and the wiring around the oil temp/pressure sending units, it's all in the aoa(angle of attack)
Old Sep 17, 2005 | 02:27 AM
DPG's Avatar
DPG
St. Jude Donor '06
cool, thanks guys, i will tackle this again in the morning. If i have any more problems, i will let you know.... again thanks for the responses and suggestions....
Dave
Old Sep 17, 2005 | 09:40 AM
molson's Avatar
molson
I did mine from the top....
Undo the steering shaft and move it out of the way,then disconnect the fuel lines and it should go in pretty easy.
Old Sep 17, 2005 | 10:39 AM
SteveDoten's Avatar
SteveDoten
that works for kooks, unneccessary work for dt's
Old Sep 17, 2005 | 03:26 PM
DPG's Avatar
DPG
St. Jude Donor '06
Thanks for your help guys, squeezed em through the bottom by raising the car super high, but it worked. Wish I would have done that earlier. Oh well, now I know. Thanks for the help and suggestions
Dave
To dynatech header install
