Auto lock fix?
Old Sep 16, 2005 | 10:09 PM
Rickmd's Avatar
Rickmd
Default Auto lock fix?
Is there some type of "fix" to turn off the auto locks on a 01 vert.
I hate it, it would not be so bad if the car unlocked once its turned off, but it doesnt
Seeing how they have a harness/fix for just about anything now, was hoping they had somthing for this..
OH btw i did try to do a search, but came up empty.
Old Sep 16, 2005 | 10:33 PM
MagRedSkull's Avatar
MagRedSkull
Default Yes - Program it
I have a pdf of the 2001 owners manual so I searched the pdf. On page 2-101 it documents:
"Auto Lock
Press the OPTIONS button until AUTO LOCK appears
on the display, then use the RESET button to page
through the following choices:
AUTO LOCK ON
AUTO LOCK OFF
If you choose AUTO LOCK ON, both doors will
automatically lock when the vehicle exceeds 10 mph
(16 km/h) in a manual transmission. In a vehicle with an
automatic transmission, both doors will automatically
lock when you move the shift lever out of PARK (P).
Choose AUTO LOCK OFF to turn this option off.
Auto Unlock
The AUTO UNLOCK will be available only if AUTO
LOCK is set to ON as described previously.
Press the OPTIONS button until AUTO UNLOCK
appears on the display, then use the RESET button to
page through the following choices:
AUTO UNLOCK DRIVER
AUTO UNLOCK BOTH
AUTO UNLOCK OFF
If you choose AUTO UNLOCK DRIVER, the driver’s
door will automatically unlock when you turn the
vehicle off and pull the key out of the ignition.
Choose AUTO UNLOCK BOTH, and both doors will
automatically unlock when you turn the vehicle off and
AUTO UNLOCK OFF turns off this option."
I hope this helps.
