I have all the intake bolts out, disconnected the injectors, air cleaner and the vacuum hoses I can see.
My problem is the intake lifts up but I can’t get it to move forward?
I can’t see what’s holding it back?
I’m trying to move it forward to replace the oil pressure sensor.
There is a gigantic vacuum line on the back as well as a smaller one. Also, the bolts tend to drop down and hang up sometimes.
Check jmx's site. www.ls1howto.com
