How does Miles to Empty work?
Old Sep 18, 2005 | 08:35 AM
Digmo's Avatar
Digmo
Default How does Miles to Empty work?
OK, I was returning from Effingham and Reserve Fule light came on with 82 miles remaining fuel. My average MPG was 28.9. I pressed reset and continued on. The fuel gauge was between the bottom two RED lines and I had NO further notice in DIC but, I ran out of nerve and filled up as I did not want to run out of gas. DIC indicated 62 miles of remaining fuel. My average was 28.9. Took 15.656 gal. to fill. Hand calculated MPG was 27.7. Distance to home was 30 miles, would I have made it without running out of gas? How are the numbers calculated by DIC?
Ray
Old Sep 18, 2005 | 10:06 AM
MY1STPEWTER's Avatar
MY1STPEWTER
Yes, you would have made it home. I believe the way it works is the way you have been driving the car. If you were in 6th gear doing 2000 rpm and it showed 82 miles remaining then if it had been in fourth gear doing 3500 rpm it might have shown 60 miles remaining. Works on the avg mpg you are getting.
Old Sep 18, 2005 | 10:15 AM
Digmo's Avatar
Digmo
Thanks, I was all 6th gear Xway driving. How low have others gone without running out of gas?
Old Sep 18, 2005 | 01:05 PM
Digmo's Avatar
Digmo
ttt, where in shop manual should I read?
Old Sep 18, 2005 | 01:06 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I have made it to 24 miles and filled up.
Old Sep 18, 2005 | 03:56 PM
johnnyvettes's Avatar
johnnyvettes
CHICAGO CREW !
From: We are living in a Bazzaro World everything is upside down half ass backwards !
CI 4-5-6-7-8-9 Veteran
St. Jude Donor '06-'07-'08 & '12
c5 what a car going home yesterday from funfest 29.4 mpg this is with a cam headers a4 car oh yea the air on and flying low at 95 plus all the way home !! no kidding some burst to a 110 mph ............... for all the kids on the forum I was dreaming all this
Old Sep 18, 2005 | 05:00 PM
RocketSled_Z06's Avatar
RocketSled_Z06
8th Gear
It estimates how much fuel is in the tank using the same senders that make the fuel gage work. It takes the current Average MPG and multiplies by that estimate.
The Average MPG is a rolling average, the input is the Instaneous MPG value. I have never been able to figure out what the interval is, though it's long. When you've been driving around town averaging 17MPG and you hit the highway, it takes quite some time before the Average comes up to the current, better highway MPG.
You can reset the Average when selected in the DIC by pressing and holding the RESET button. It'll beep and the rolling average calculation will reset to Zero. Then you'll see it changing fairly rapidly, as it tracks the faster Instaneous MPG value changes. After a while, as the new Average builds up, the Instaneous has less effect and the Average "settles out".
If you check your Range on the DIC, then reset the Average, then switch back to Range, you'll see the Range value changing, just like the Average value changes after the RESET.
MPG changes as a function of your current driving condition, so Range does too. To get a best estimate of your remaining Miles for any given situation, reset the Average, continue driving for a few minutes, then check the Range.
Old Aug 27, 2022 | 08:27 PM
Markmbaha1's Avatar
Markmbaha1
If the fuel gage is malfunctioning, does that make the distance to enpty bogus? I've seen fuel gage littke over 1/2 full but distance to empty showing 22 at a used car dealer who never has but a drop of gas in his cars.
Thank you
To How does Miles to Empty work?
