A4 Transmission Question
Old Sep 18, 2005 | 12:45 PM
fast 98 C5's Avatar
fast 98 C5
Default A4 Transmission Question
I am looking to upgrade the A4 cooling capacity. I was wondering what others use for:
A) Cooling for A4
B) Fluid type
I am talking about a fully built bad tranny every upgrade possible.
Thanks for any suggestions.
Bill
Old Sep 18, 2005 | 02:19 PM
C66 Racing's Avatar
C66 Racing
Premium Supporting Vendor
Can't help with A, but for B I recommend AMSOIL ATF which meets GM Dexron III standards (and is the same fluid I use in my MN12 for the track).
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
Old Sep 18, 2005 | 02:58 PM
fast 98 C5's Avatar
fast 98 C5
Thanks I gotta look into this.
Bill
Old Sep 18, 2005 | 03:13 PM
frank dupuy's Avatar
frank dupuy
I installed a large stand alone tranny cooler to my A4. It now doesn't overheat on track days etc. The rest of the tranny is stock,running 470 RWH and keeping my fingers crossed.
Old Sep 18, 2005 | 08:47 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
JEGS has a 2 quart xtra trans pan .Its a TCI part# 890-378000 fits TH-700R4 & 4L60E. Fits perfect.And I run Amsoil tranny fluid.I'll post pics of it Monday night.
Old Sep 18, 2005 | 08:51 PM
flatlne's Avatar
flatlne
call Roney at RPM trans pm if you can't find his#, ask him He just did my tranny
Old Sep 18, 2005 | 10:24 PM
Dirty Howie's Avatar
Dirty Howie
How much are these?
Can they be installed without droping the drive train??
What if your car is lowered?????
DH
Old Sep 19, 2005 | 01:37 AM
MTV's Avatar
MTV
St. Jude Donor '03-'04-'05
Originally Posted by Dirty Howie
What if your car is lowered????? DH
Then you can't have one High water Howie!
Old Sep 19, 2005 | 01:59 AM
SFVetteman's Avatar
SFVetteman
As far as the fluid goes, if you have a built tranny then you should check with the builder before using synthetic ATF. Synthetic ATF like Redline or Amsoil can be incompatible with the clutches that are used.
Unless you are using the car on a road course, the B&M 70266 should be able to keep your A4 under 200 degrees even in the Texas heat
Old Sep 19, 2005 | 03:52 AM
Mitch C's Avatar
Mitch C
FLP does not recommend sythetic ATF with their trannys.
Old Sep 19, 2005 | 02:21 PM
ItsFrench's Avatar
ItsFrench
Old Sep 19, 2005 | 09:01 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Dirty Howie,The TCI trans pan is $129.99,Comes w/gasket& bolts.Just take off old pan put new one on very simple,Of course you have to have the car jacked up, and you can use the stock filter too.The only problem is it does'nt have a fill plug only a drain plug.Jegs has a trans pan drain plug kit.Part #555-60175 $6.69.What I did I disconnected the top line off the rad and pumped the tranny fluid through that line with a fuel pump I had.I made sure the fluid went in before I put the new pan on.My car is lowered and there is no clearence problems.I posted pics before,as soon as I figure out how I did it I will post them.
Old Sep 19, 2005 | 09:20 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
http://www.tinypic.com/view/?pic=dvoxvp
Old Sep 19, 2005 | 09:22 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
http://www.tinypic.com/view/?pic=dvotwm
Old Sep 19, 2005 | 09:25 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
http://www.tinypic.com/view/?pic=dvoyoo
Old Sep 20, 2005 | 01:52 AM
Dirty Howie
Paul:
Thanks for the pics. Looks like it has some cooling fins as well ?
Your car does look low. Mine is 26 front and 27 rear...ground to fender well lip.
So you are saying there is no side mounted fill hole. I didn't even realize this hole is on the pan even though I've watched the tranny fluid being toped off twice during moding. So since the correct fill is to have the tranny fluid coming out the side as you plug it.....how do you know if you have the correct level???????
DH
Old Sep 20, 2005 | 02:54 AM
MTV's Avatar
MTV
Paul: So since the correct fill is to have the tranny fluid coming out the side as you plug it.....how do you know if you have the correct level??????? DH
High Water Howie....
The Tranny fluid capacity sensor in your DIC needs to be reprogrammed to account for the extra capacity provided by the TCI trans pan. Very slick mod!
mtv
To A4 Transmission Question
Old Sep 20, 2005 | 04:51 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
I took out exactly 3 1/2 qts. so I put back 5 1/2.You can drill a hole in the side of the pan,Jegs has a plug kit thats a bolt on
Old Sep 20, 2005 | 06:28 PM
Dirty Howie
Thanks for all the info...
DH
Old Sep 20, 2005 | 07:30 PM
DRIVER456's Avatar
DRIVER456
St. Jude Donor '07
Any time
