On the two aftermarket units I bought for the oil cooler I installed, I have a seeping problem. Otherwise, it is not leaking much... just a slight mist around the filter and pan in that area.
You may have to replace the aluminum housing the sensor is in.
Mike
I never thought of that. That's a possible solution. I'm still under warranty. But, I hate to take it to the dealer.
