Any tips on flushing the C5's cooling system?
Old Sep 19, 2005 | 12:25 PM
chuck1026's Avatar
chuck1026
Cruise-In II Veteran
Default Any tips on flushing the C5's cooling system?
Hey:
I am going to be flushing the cooling system in my C5, as the Dex is now coming up on 5 years... Everything looks clean, so I plan on running tap water thru to clear out the old, and then add Dex to get the 50% mix.
Anyone with experience who can offer some time saving / trouble prevention tips, please chime in .
Thanks in advance!
Old Sep 19, 2005 | 01:19 PM
djengr's Avatar
djengr
I have not done on mine yet but many after a flush with tap water prefer to fill back up with a mix of antifreeze and distilled water.
Old Sep 19, 2005 | 03:42 PM
2kbluestreak's Avatar
2kbluestreak
I've previously posted a procedure I developed for my C5, but I haven't received much positive feedback. I think the owner's manual says the C5 cooling capacity is about 12.5 quarts. When you open up the petcock under the radiator, you only get about half of this amount out. Therefore, there's still about 6-7 quarts in the block, H2O pump, heater core, or wherever. There's supposed to be drain plugs on each side of the block, but I don't think they are very accessable or practical, so what I do is force water through the coolant system to purge out all the old coolant. To do this, I bought 8" of 2"dia. radiator hose that I hose clamp to the inlet on top of the recovery tank. With PVC fittings, I made a hose adapter to clamp to the other end. I then run city water through the coolant system until the discharge from the radiator starts to run clear. I then close the petcock and turn on the engine until it reaches operating temperature with the heater running. I then open the radiator drain and run for another 5 minutes. This appears to purge all the old coolant out of the system. Let me know if you want to know what to do next.
Old Sep 19, 2005 | 05:00 PM
FKING1's Avatar
FKING1
Taking mine to a Dealer where they hook the system up to a machine and power flush it with some solution.
Fred
Old Sep 19, 2005 | 05:27 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Fred
I did that, it changes 100% of the fluid. Less time and less mess.
Old Sep 24, 2005 | 03:34 AM
chuck1026's Avatar
chuck1026
I am a DIY kind of guy... I dread letting others service my C5, so I am going to do this myself.
Old Sep 24, 2005 | 02:57 PM
Oldvetter's Avatar
Oldvetter
Be careful opening the radiator drain plug, it only turns 90 degrees. You can break it if you turn it too far, it does pull out.
The shop manual says you don't have to flush the system if it is clean. My 1998 was clean in 2003, so I just refilled. You must top it off 3 times, reving engine to 3,000 rpms to get all air out of it. Mine drained almost all (12 quarts) out of system. I left car down (off jack) so that it was level when draining.
Use distilled water for mixing.
Old Sep 25, 2005 | 02:24 PM
chuck1026's Avatar
chuck1026
My Dex looks great, so I will do the same. Thanks for the tips .
Old Sep 25, 2005 | 04:28 PM
2KREDVert's Avatar
2KREDVert
I guess it depends on how good your tap water is but it would be terrible to ever mix any tap water in a cooling system here. Too many minerals in the water. I would use only distilled water, even just to flush. NEVER any tap water!
Old Sep 25, 2005 | 05:48 PM
edensknight's Avatar
edensknight
I prefer using distilled water to flush completely. BTW, Chuck, I love that cool pic of your car in your avatar. Nice photo.
Old Sep 26, 2005 | 10:49 AM
BananaVett's Avatar
BananaVett
The old way of flushing out the old engine anti-freez with a garden hose going down the driveway and into the local sewer is a no-no in my state .
Therefore, flushing out your engine is no longer praticle for most backyard mechanics unless their is a holding tank involved, and taking the used fluids to a recylcle/reclame center just like used oil. Getting ticketed for this stunt is extreamly costly . Better to take your auto to someone who has the equipment and knowhow. I would think that most states have these dumping codes.
Old Sep 26, 2005 | 11:25 AM
Randy@DRM's Avatar
0Randy@DRM
Former Vendor
Make sure you clean out all the leafs and trash from the front of the radiator.
Randy
Old Sep 26, 2005 | 12:55 PM
TomT's Avatar
TomT
The problem with letting a shop do it is that they don't refill with distilled water. I even left 2 gallons of distilled water for a garage to mix in another car of mine. They forgot and put in tap water.
Old Sep 26, 2005 | 09:53 PM
Oldvetter's Avatar
Oldvetter
I bought a radiator drain/flush kit (prestone) a few years ago. It included a five gallon folding jug to drain into. I have local antifreeze recycle centers. Besides being enviornmentally hazardeous, antifreeze is poisonious to dogs and cats and they are attracted to it.
I always prefer working on my own car, I know what I do is right.
Old Sep 26, 2005 | 09:56 PM
2KREDVert's Avatar
2KREDVert
Randy
What's this leafs stuff? Where did you learn your grammar?
Old Sep 26, 2005 | 10:12 PM
JON CONA's Avatar
JON CONA
Default radiator
Once You Drain, Flush, And Refill. Make Sure To Run The Engine With The Coolant Tank Cap Off A While To Let Out Any Air That May Have Been Trapped In The Sys. Good Luck.......jc
To Any tips on flushing the C5's cooling system?
