Can u plug Run Flats?
Old Sep 19, 2005 | 01:32 PM
J's Toy's Avatar
J's Toy
Default Can u plug Run Flats?
Had a nail in my tire on Sunday, took the car to NTB and was told that you can not plug run flat tires. Is this true? The nail was located dead center of the tire and the tire has maybe 55% tread life remaining. I found someone else to plug the tire...is there a risk of blowout?
Old Sep 19, 2005 | 02:34 PM
yellow01's Avatar
yellow01
You can plug them, I've had it done at about the same tire life and drove them bald and they were fine.
If you track it (track with turns) you may think otherwise (I personally wouldn't want to put that much stress and heat on a plugged tire) but otherwise I think you're fine.
Old Sep 19, 2005 | 02:42 PM
thisMSGgood4me's Avatar
thisMSGgood4me
NTB was trying to sell you a new tire. Yes a runflat can be plugged and patched on the inside and be just fine if the hole is in the tread part of the tire. You saved yourself a bunch of money by not listening to NTB.
Old Sep 19, 2005 | 02:43 PM
Sponge Vette's Avatar
Sponge Vette
St. Jude Contributor
Yes you can, they don't plug them. They have to be removed from the rim and a patch is installed. I've had mine patched for almost a year with no issues.
Old Sep 19, 2005 | 02:45 PM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
you can plug. I perfer to patch, but I think both will hold up wihtout a problem. You are downgraded one speed rating though...
Old Sep 19, 2005 | 02:59 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I had one patched where the hole was about an inch from the sidewall, I thought for sure it was a gonner but Goodyear fixed it for me.
Old Sep 19, 2005 | 04:28 PM
chazzvette's Avatar
chazzvette
I plugged mine about 300 mi ago. I need new tires that I will get in the near future, but I have not had any problems.
Old Sep 19, 2005 | 06:06 PM
J's Toy's Avatar
J's Toy
Thanks Guys (& Girls if apply). It looks as if NTB was just trying to sucker me. Man I looooove this website.
Old Sep 19, 2005 | 08:11 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
They can be safely repaired as long as the puncture is within the zone shown below.
However, they should be patched from the inside and then rebalanced, not plugged. Plugs are intended as a temporary repair.
Old Sep 20, 2005 | 08:23 AM
BlueL36's Avatar
BlueL36
Cruise-In V Veteran
Cruise-In VI Veteran
If you exceed the posted, patching from the inside is far safer.
Old Sep 22, 2005 | 09:51 PM
RED Coupe's Avatar
RED Coupe
For what it's worth, I had right front tire plugged on my 2001 Coupe with less than 2k miles on the car. Now four years later with 19K miles and absolutely no problem.
Old Sep 22, 2005 | 10:19 PM
leaftye's Avatar
leaftye
Unfortunately I've had the displeasure of using many plugs in runflats, and once installed, I've never had any problems...other than running over more screws & nails!
Old Sep 22, 2005 | 10:32 PM
VLVETTE's Avatar
VLVETTE
I was told FWIW that the tire should be patched on the inside and have a plug to keep any moisture from getting to steel belts and causing deterioration.
Old Sep 23, 2005 | 09:19 AM
2kbluestreak's Avatar
2kbluestreak
I think Goodyear's recommendation was to plug and patch. I have a fear of plugging because it involves expanding a 3/32" nail hole to 1/4" for the plug. If this is done, the steel reinforcement belt becomes severely damaged and the tire's speed rating lost. If you never go over 100 mph, you're OK. I've also read here about an umbrella patch which combines the patch and plug into a single unit.
Old Sep 23, 2005 | 10:47 AM
RED Coupe's Avatar
RED Coupe
As was explained to me almost 5 years ago and now nearly 18K miles later, patching is nessecary if the tire was used in run-flat mode for any period. If little air was lost when the item(nail etc) is discoverd and its in the meaty part of the tire plugging is perfectly ok. This was explained to me by the tire shop that did the plug nearly 5 years ago. Have had absolutely no problem since then, haven't lost a single pound of air other than variations due to temperature.
Appears many of our forum familiy over-lament on this topic. Just use good judgement, sure there are conditions. If the tire is not sidewall damaged, not been used in run flat mode, a relatively clean puncture(not glass etc), not too large, and tire not worn out and due to be replaced it's certainly a candidate for a plug. I can attest to that.
To Can u plug Run Flats?
