Digital Climate control
Old Sep 19, 2005 | 11:15 PM
bluemotev's Avatar
bluemotev
Default Digital Climate control
Anyone know if its possible to switch from the regualr climate controls to the digital climate controls? Is it plug-and-play or are there other things that need to be done?
Old Sep 19, 2005 | 11:21 PM
JTS97Z28's Avatar
JTS97Z28
To answer your question it is NOT a plug and play swap. Not even close! Unfortunately. I have looked into this long ago when I bought my 99 hardtop and after some research I found that it would be easier to actually sell your car and buy a dual zone a/c equipped car. There are many sensors, wire harnesses, and modules to name a few of the items you will need to do the swap. I dont even mind my basic turn **** controls anymore even more so now that there is literally one new post a day on the dual zone a/c malfunctioning.
Hope this answers your question.
JT
Old Sep 19, 2005 | 11:26 PM
bluemotev's Avatar
bluemotev
Well, in the event of not wanting to sell my car - anyone know of a workaround or way to get this to work?
Old Sep 19, 2005 | 11:35 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Troll E-bay or the parts section here. PM karshop, see if he has one.
Old Sep 19, 2005 | 11:40 PM
bluemotev's Avatar
bluemotev
I've already picked up the unit... I just need to know how to get it to work now...
Old Sep 19, 2005 | 11:52 PM
JTS97Z28's Avatar
JTS97Z28
Well to start I know for a fact you will need a completely new interior dash wire harness for a dual zone a/c equipped car. This harness will also have plugs for the new sensors and actuators that will go under the dash. I know there are exterior and interior temp sensors. I am searching around now trying to find a more detailed list for you.
Old Sep 19, 2005 | 11:56 PM
screw991le's Avatar
screw991le
The two do not work, it is not plug and play, from what I understand.
Old Sep 20, 2005 | 12:10 AM
bluemotev's Avatar
bluemotev
Cool thanks. Let me know if you find anything out...
Old Sep 20, 2005 | 03:12 PM
white90conv's Avatar
white90conv
I don't know why you want the digital control. I have never liked automatic air conditioners - they never seem to get the temperature right. I have the digital unit and am always fiddling with so its "automatic" advantage is minimal. It also has a reliability problem with the dimming display. I think you should be happy you don't have it.
Old Sep 20, 2005 | 08:55 PM
bluemotev's Avatar
bluemotev
Well, I guess I don't REALLY have to have one. But, my controls went out on me (at least I think thats what it is, it still blows cold but will not change from face/feet setting). I figured since I have to replace the controls, I would try to go digital. I can't seem to find the regular controls anywhere and was only able to find the digital ones. For now I wouldnt mind going with the regular ones just to get it working right, since I am assuming that is what needs to be replaced. But, I would like to look into this for a future mod. Mainly because it looks cooler
Old Sep 20, 2005 | 10:12 PM
white90conv
You probably have a vacuum line problem. It is probably not the control head.
Old Sep 20, 2005 | 10:44 PM
warren s's Avatar
warren s
I wish I could change my digital control to the basic *****!!!!
Old Sep 21, 2005 | 01:02 AM
bluemotev's Avatar
bluemotev
How would I go about checking that?
Old Sep 21, 2005 | 07:56 PM
bluemotev's Avatar
bluemotev
Before I go about replacing this thing, can someone point me in the right direction as to how I can check if its a vacuum line problem?
Old Sep 25, 2005 | 10:35 PM
bluemotev's Avatar
bluemotev
anything?
To Digital Climate control
