Uneven rear 1 year post lowered
Old Sep 20, 2005 | 10:28 AM
GMvert's Avatar
GMvert
Default Uneven rear 1 year post lowered
It has been at least a year (lowered on stock bolts) and the rear measurements are: R="27'' 1/2 and L=28'' 3/4. I looked at both bolts and they are only showing 2 threads. What do I need to do next?
Old Sep 20, 2005 | 10:55 AM
SpeedyD's Avatar
SpeedyD
How's it going, I am pretty new to the corvette world and I hope you can explain to me what "lowered on the stock bolts" means. I have seen this phrase used many times but not quite sure how you lower a car on "stock bolts". The only way I ever knew was by changing out the springs or changing over to a coil over suspension. Thanks for the help, Dan
Old Sep 20, 2005 | 11:13 AM
allanlaw's Avatar
allanlaw
There is a range of height adjustment possible by turning the bolts that attach the springs to the moving suspension units (one at each wheel).
Old Sep 20, 2005 | 11:15 AM
SpeedyD's Avatar
SpeedyD
So you're saying without any mods to the suspension I will be able to lower my Vette? I'm sure I would need a new 4 wheel alignment, correct? How much can it be lowered on stock bolts? Thanks again, Dan
Old Sep 20, 2005 | 11:18 AM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
You can lower it about 1 inch on stock bolts alone, you will need a 4 wheel alignment which I don't know if the original poster did. You have to wait about 300-500 miles before doing the alignment though since the car takes some time to settle.
Old Sep 20, 2005 | 11:19 AM
SpeedyD's Avatar
SpeedyD
Thanks for the help!
Old Sep 20, 2005 | 11:20 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Mine is the same way.
Old Sep 20, 2005 | 01:10 PM
lost's Avatar
lost
An inch and a quarter would be quite noticable, could we see some pics.Mine is untouched and 27 3/4" on both sides.
Old Sep 20, 2005 | 07:47 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
GMvert,your better off getting longer bolts so you can adjust each side so they match.http://www.tinypic.com/view/?pic=dw9wed
Old Sep 20, 2005 | 09:55 PM
corvette dave's Avatar
corvette dave
Something does not sound right. No offense, but are you sure the left measurement is 28 3/4"? The right side height sounds about right.
Do you have the stock heights and the heights after you lowered the car? That would help sort this out.
Old Sep 20, 2005 | 09:57 PM
bcseitz's Avatar
bcseitz
Ok Guys. These are adjustment bolts. You use them to lower the car as well as LEVEL the car!
If your adjustments are as low as they can go, the only thing you can do with them now is raise one or both.
If one side is lower than the other AFTER the bolts are adjusted as low as they can go, you have to adjust the low side of the car up. Adjust that bolt until the car sits level.
Don't forget that when you raise or lower one corner of the car at the rear, that also affects the front of the car also. You have to make the appropriate adjustments on the opposite end too.
It takes a little time!
Bob
Old Sep 20, 2005 | 10:14 PM
mvvette97's Avatar
mvvette97
Bob
I raised the one side back up some. It did level it out some. I just don't know why there would be a differance when the bolts are the same size. Live and learn I guess
Old Sep 20, 2005 | 10:47 PM
bcseitz's Avatar
bcseitz
It's not the bolts, they are the same length. It's the spring and also the difference in the weight it has to carry on each of the four corners of the car not to mention if it's perfectly centered in it's perch. The longer side would (should) be the weaker side.
My car was also higher on the LR than the RR. It was also a bit lower on the LF than the RF. Took a bit of tweeking but it sits level now.
I would imagine that you would have to go through a whole pile of springs to find a perfect pair that have the proper arc and tension each side of center. Perhaps the more expensive springs designed for the track have been tested for just that.
Old Sep 20, 2005 | 11:06 PM
mvvette97's Avatar
mvvette97
Yea I agree with ya. I never thought about it being the spring. The front seems to be fine. I think I'm going to get some longer bolts for the rear so I have some more adjustment that way I can keep it level on the front and rear. I don't want it looking like a 70s Nova.
Old Oct 1, 2005 | 03:31 PM
touring2's Avatar
touring2
Default lowering the car
Are you sitting in the car while someone does the measuring. It would be a bit of(mine is) with no driver weight.
Old Oct 1, 2005 | 11:24 PM
corvette dave
The amount of fuel in the tank can also play havoc with your readings.
The difference in heights between a full tank and an empty one is about 3/16".
Old Oct 2, 2005 | 12:02 AM
GMvert's Avatar
GMvert
Thanks for the replies. It does not matter any more because I am going to further lower with longer bolts in the back, trim the front, and put Bilstein shocks on a soon as I recover from shoulder surgery. Also I have rocker rail savers on order with frame savers already on. I am just getting started on this baby.
To Uneven rear 1 year post lowered
Old Oct 2, 2005 | 12:59 AM
edensknight's Avatar
edensknight
Get well soon with that shoulder. Basically, your plan above sounds good (longer bolts, bilsteins, and, alignment, etc.). You are on the right track, good buddy. Do let us know how it all turns out for you. Best wishes.
Old Oct 2, 2005 | 02:00 AM
mvvette97's Avatar
mvvette97
Got mine aligned the other day. After I cut the front bushings and got longer bolts for the rear it sets level. In case any of you read my thread the other day about the dealer breaking my rocker panel well they fixed it as good as new. The alignment made it drive alot better also.
Old Oct 2, 2005 | 05:26 PM
VetteLooking's Avatar
VetteLooking
Have you measured to the frame rails? Although this is a lot of difference, the real measurement should be the same location on the frame on either side of the car.
There is too much tolerance stack measuring at the top of the wheel well to tell if the issue is actually a suspension issue or a body panel issue.
