Missfire help plz
Old Sep 20, 2005 | 11:44 AM
killaz's Avatar
killaz
Default Missfire help plz
So i did a clutch install this weekend. Took it for a drive, clutch works fine, but now i have a missfire. I have checked all the plug wires and they look good. I got the codes as follows.
p0300
b1001
u1040
u1064
u1016
u1096
c1242
I also reused the air tub gaskets could that be an issue if they are leaking? Any info would be great...
Old Sep 20, 2005 | 11:47 AM
killaz's Avatar
killaz
also the missfire is from 1000 rpm to about 3000 rpm. If i jump on it, it will take off.
Old Sep 20, 2005 | 03:57 PM
killaz's Avatar
killaz
ttt
Old Sep 20, 2005 | 10:02 PM
WDDarts's Avatar
WDDarts
Default Misfire
I had the same thing happen today. I eyeballed the plug wires and they looked ok. When I physically checked them though the wire on the drivers side rear was in fact a bit loose. Caused the same symptoms you are having. That is a tight area but on my fifth try (or so) of squeezing my hand down in there I was able to get it seated all the way in. Fixed the problem.
If all seated maybe a bad wire or bad plug??
Good luck.
To Missfire help plz
