will this change help performance
Old Sep 20, 2005 | 09:47 PM
JimK-98's Avatar
JimK-98
Default will this change help performance
Ordered Z06 cam,beefer push rods,Z06 valve springs,Dynatech long tube headers, cats, Xpipe, Corsa Indy Mufflers.
'02 conv. Automatic
3:15 gears
1.98@60'
8.35@1/8 mile@86.88
12.88@1/4mile@107.68
Dyno@ 303HP@319Torq.@Funfeast on 8/17/05 "STOCK"
They said my timing was not advancing correctly on print out of run
Old Sep 20, 2005 | 09:51 PM
Silver98's Avatar
Silver98
uhhh, ... yea
Old Sep 20, 2005 | 10:35 PM
Mitch C's Avatar
Mitch C
'02 conv. Automatic
3:15 gears
1.98@60'
8.35@1/8 mile@86.88
The Z06 cam is a step up from the stock cam. However there are lots of cams that will give you much better performance than the Z06 cam. For example the TR224/224 or the FM4.
IMO with an A4 you will get much more bang for the buck if you install a high stall T/C like the SS3200 instead of the Z06 cam. Or better yet install a higher stalling T/C with a bigger cam.
To will this change help performance
