Is this normal?
Old Sep 21, 2005 | 08:15 AM
TomZ's Avatar
TomZ
Default Is this normal?
I recently picked up an '01 after passing all my sniff tests (clean carfax, great condition interior and exterior, no leaks, plenty of power, etc). However, after I brought it home (of course) I noticed a bit of a rough idle. The tach holds steady, though, so I'm not sure if it's in my head or what, but it seems to almost "miss" about every 2-3 seconds. Could this be from lack of use (since it only has 17K miles on it)? Should I start by putting some Techron in it, or is this possibly a sign of a serious engine problem?
Thanks for any help.
Tom
Old Sep 21, 2005 | 08:32 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
Start with the basic checks........ Air filter, plugs, etc. Is the gasoline old?
Old Sep 21, 2005 | 08:35 AM
TomZ's Avatar
TomZ
I don't think the gas is old (the guy seems to have taken care of it). If anything is gummed up is there a product out there to come to my rescue or am I in for a big headache?
Old Sep 21, 2005 | 08:51 AM
see5's Avatar
see5
If it is serious it should throw code on DIC. You could have it dealer checked but I would give it some time.
Old Sep 21, 2005 | 08:54 AM
TomZ's Avatar
TomZ
So possibly the problem could work itself out over time if I put some fresh gas thru it (provided no problems with plugs, air filter, etc.)?
There aren't any codes being thrown.
Thanks, everyone.
Tom
Old Sep 21, 2005 | 09:22 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
Give it a couple of tanks of Chevron 93 with Techron. Then run the H--- out of it to clean it out.
Old Sep 21, 2005 | 09:31 AM
Tsab's Avatar
Tsab
It could be a sticky injector or a plug fouling, no codes thrown I would just run a couple of tanks of gas through it and maybe change the spark plugs. Since its an 01, keep an eye on your oil consumption. Good luck with your new ride
To Is this normal?
