Has anyone adjusted the convt top on the rear deck. Previous owner had dealer adjust because it was leaking...one side looks flat on deck now but otherside is not very tight on the deck.
There is a adjustment rod (about 18" long) on each side you can see when the top is in the folded up position and looks like it would be the one to adjust to make the back of the top fit to the rear deck better.
Any experience with this would be appreciated....as it looks like a minor adjustment. Thanks Mike
Thanks Cenzo.....that's exactly what i was looking for and comfirms what i thought so i won't screw it up.......You are 5 stars and i have a new site to check on things....so much appreciated.
