Anyone ever seen a block crack...
Old Sep 24, 2005 | 12:13 AM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Default Anyone ever seen a block crack...
Anyone ever seen a block crack behind the liner but not have the liner cracked?
Another oddity was that this liner was dropped down.... at least several thousands below the deck. I thought that these "cast in place" pieces could not do that.
Any insight appreciated.
Charlie
Old Sep 24, 2005 | 10:44 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
I've never heard of that happening, the block probably had a flaw in it right where it cracked.
Old Sep 24, 2005 | 11:17 AM
RED99's Avatar
RED99
Maybe someone or the factory had re-sleeved that one cylinder for some reason, and they cracked the case pressing it in!
Old Sep 24, 2005 | 11:43 AM
blu00rdstr's Avatar
blu00rdstr
Nope. Cracked the #7 liner in an LS1 block in 2003 at 9psi, from the stock pistons trying to compress pieces of ring landing in the quench area. The pistons twisted on their pins, and the pressure from the piston skirt cracked the cylinder wall.
Cracked the #3 liner in an LS6 block last month, even though the that one piston was undamaged.
Old Sep 24, 2005 | 01:03 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
Yeh but you cracked the liner under boost, charlie's block is cracked behind the liner
To Anyone ever seen a block crack...
