Rear Diff Rebuild... Questions...
Old Sep 26, 2005 | 12:31 AM
24hr Z06's Avatar
24hr Z06
Default Rear Diff Rebuild... Questions...
Prior to installalation of the following..
1. The dynotech brace,
2. Hardened output shaft
3. Red-Line Synthetic 75W90 Gear Oil...
I just wanted to know which seals and gaskets should be replaced?
Thanks..
Old Sep 26, 2005 | 12:00 PM
Mike Mercury's Avatar
Mike Mercury
Thanks..
I have the part numbers for the newer "O" rings - near the bottom of my web page:
http://mikemercury.home.att.net/342.htm
Old Sep 26, 2005 | 01:13 PM
24hr Z06's Avatar
24hr Z06
Thanks Mike, great website.. I actually ordered the tranny jack that you used for the install..
Couple of questions..
I was planning on replacing the 3 lip seal, part #88996703, I was just wondering is that only for the drivers side or is that the same for both sides?
What is the output shaft(s) center seal p/n 89047953 for?
And last but not least.. What is the center-shaft seal p/n 24207010 for??
This is all for a Z06..
Old Sep 26, 2005 | 06:31 PM
Mike Mercury
actually, all I have are the part numbers. I never replaced any seals because I bought a brand nrew carrier when i did my rear axle ratio upgrade.
Someone here will chime in.
To Rear Diff Rebuild... Questions...
