AN6 to A4 transmission?
Old Sep 26, 2005 | 11:47 AM
Fast one's Avatar
Fast one
Default AN6 to A4 transmission?
What fittings are needed to plumb an AN6 line to the A4 transmission to add an external cooler? The stock cooler lines won't be used, just disconnected and moved out of the way. The stock flared fittings screw into what look like 1/2" NPT pipe fittings that are in the transmission case, are these fittings NPT or do they use a copper gasket like brake fittings?
