alignment & lowering questions
My current alignment specs are:
front:
camber left -1.50 right -1.46
caster left 7.54 right 7.07
toe left -0.66 right -0.68
rear:
camber left -0.93 right -1.04
toe left 0.62 right 0.57
Always used basically stock settings in the past, these new settings are a tremendous improvement in driving the twisties and in the one solo 2 I ran since the change.
I think the rear camber is hurting drag racing traction and the toe settings probably don't do any good for rolling resistance or tire wear.
How much toe do I have in inches?
If I lower the rear of the car using only the stock bolts, how much will that change the alignment settings?
Anyone tried the Hardbar camber things? How difficult is it to change camber settings for different uses?
http://www.vbandp.com/instructions/...truct/align.htm
97-04 C-5 Corvette - Possible settings
Front Toe
1/32" in Daily Driver
0" to 1/32" in Advanced Street
1/16" in Autocross Baseline
1/8"out-1/32" in Track Baseline
Front Camber
0° Daily Driver
1/4° neg Advanced Street
1/2° neg Autocross Baseline
1/2° neg Track Baseline
Front Caster
6-7° pos Daily Driver
6-7° pos Advanced Street
4-6° pos Autocross Baseline
4-6° pos Track Baseline
Rear Toe
1/16" in Daily Driver
1/16" in Advanced Street
1/16"-1/4" in Autocross Baseline
1/8"- 1/4"in Track Baseline
Rear Camber
0° Daily Driver
1/2° neg Advanced Street
1/4 - 2° neg Autocross Baseline
3/4 - 2° neg Track Baseline
