Spark plug gap???
Old Sep 27, 2005 | 08:07 PM
Gary2KC5's Avatar
Gary2KC5
Default Spark plug gap???
what's the gap for NGK TR55's?
Thanks!
If it matters, it's got most bolt on mods, moderate heads (1.57/2.02) and a moderate cam (.558/.558 .224/.224 114)
Old Sep 27, 2005 | 08:12 PM
AMGPilot's Avatar
AMGPilot
Stock gap for a 2000 C5 is .060 inch.
I am not sure if you should adjust the gap for the mods you have.
Old Sep 27, 2005 | 09:38 PM
Gary2KC5's Avatar
Gary2KC5
Thanks Jack!
I don't think the mods matter, but incase they do...
Anyone else?
Old Sep 28, 2005 | 01:13 AM
boosted_z06's Avatar
boosted_z06
rule of thumb is for about every 75 HP gain gap should be reduced by .004.
But you cannot change the gap more then .004 +/_ of what the plug was designed to so if you wanted to go with a .040 gap you would have to use a different plug that was designed for about that gap.
If your running a header with mods also best to drop down one step colder so a NGK TR-6 is a step colder and designed for 0.40 gap.
Newest GM plugs are designed differently then what C5s used to use where they ran a .60 where new ones are .40 but are still a hotter plug.
Old Sep 28, 2005 | 08:33 AM
6Speeder's Avatar
6Speeder
My motor is simular to yours, but with 11.4 cpmpression. I'm running .050" gap. Runs good, but then it ran good with the stock plugs even after the pucks came off and the gap was .070"
What do you guys think it should be?
Old Sep 28, 2005 | 11:54 AM
RaVolt's Avatar
RaVolt
My engine is still stock (put on a Blackwing, but no engine changes). I set the gap on the NGK TR55s for mine (2002) at .055
Runs great for me.
Old Sep 28, 2005 | 12:48 PM
luv2fixit's Avatar
luv2fixit
Default maybe gap is my problem.
I just removed the stock plugs and installed a set of boshe paltinum plus 4 plugs and the car barely runs, at Idle it misses and under a load it bucks and feels like it is running on 4 cylinders. I verified all electrical connections and verified all plugs were firing (at idle), but the car runs like hell! Maybe It has somthing to do with the preset gap on the 4 electrode boshe plugs?. Does anybody want to chime in about this one? Is it a must that I use these NGK tr55's in my car? the stock plugs were .080 and seem to run ok?
To Spark plug gap???
