Need lowering info
Old Sep 28, 2005 | 11:57 PM
striper's Avatar
striper
Default Need lowering info
I already lowered my car to the max on stock bolts. I would like to know what measurements those who done this have gotten from the top of the wheel wells to the ground, f & r. Also, does anyone know how much lower the front will go if cutting the front bushings.
Old Sep 29, 2005 | 01:18 PM
DJMRTS's Avatar
DJMRTS
I'm at 26" up front and 26 9/8" in the rear with cut bushings. You should expect a difference of 3/8" to 1/2 " between non-cut bushings and cut bushings. Also make sure you give it some time to settle (200 miles or more) and then do an alignment.
Old Sep 29, 2005 | 08:16 PM
mixermike's Avatar
mixermike
i,m at 26" front,27 1/4" rear with cut bushings
Old Sep 29, 2005 | 08:34 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
Originally Posted by DJMRTS
and 26 9/8" in the rear...
Is that a typo, or does it sound more impressive than saying 27 1/8", or are ya just having fun with fractions? :
My car is at 5 166/8" front, and 3 188/8" rear, cut front bushings and longer rear bolts.
That's 25 3/4" and 26 1/2" for the math-challenged
Old Sep 29, 2005 | 10:00 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
i like the 'fun w/ fractions'
Old Sep 29, 2005 | 10:34 PM
xjcharity's Avatar
xjcharity
St. Jude Donor '21
26 1/4 front, 26 3/4 rear.
Old Sep 30, 2005 | 01:05 AM
DJMRTS's Avatar
DJMRTS
Old Sep 30, 2005 | 05:15 PM
FKING1's Avatar
FKING1
25-3/4 frt & 27 rr, with cut bushings and longer rr bolts.
Fred
To Need lowering info
