Reading Oil Stick...??
Old Sep 30, 2005 | 08:27 AM
Net Exploit's Avatar
Net Exploit
Default Reading Oil Stick...??
Ok, I messed up and overfilled when changing the oil
What is the highest the level the oil can be on the stick.
I see the add line, then another section then a line with the arrow pointing to it which appears to be the high level. My oil level is about another section above that.
I thought the container was 4 Qts, but no it is 5, so I think I have 7.5 qts in instead of 6.5
Old Sep 30, 2005 | 09:42 AM
MHVette's Avatar
MHVette
I consistently add 7 qts to fill mine up... 6.5 never seems to get it to the line??? People overfill their C5's by a half a qt to 1 qt before a track day to reduce the chance of oil starvation all the time. I wouldn't worry about it because it will burn off. You can always loosen the bolt and let a little out. IMHO
Old Sep 30, 2005 | 09:59 AM
Beezvette's Avatar
Beezvette
It will vary, depending on the year. I have an 01 M6 and it takes 7 to fill 2/3 of the way up the cross hatch. I think 7.5 is too much, but I'm no mechanic. I'd remove a half quart to be safe. I'm told by people who service c5s that they take any where from 6.5 to 7.25 quarts to fill. I'm also told that half way up is "full" since the oil expands when hot. Not sure how valid that is either.
Old Sep 30, 2005 | 10:05 AM
avacorvette's Avatar
avacorvette
From: Canonsburg home of Yenko Chevy (gone but not forgotten) Western PA
Default don't do it
Do not over fill oil more than 1/2 qt.
High pressure can bild up and cause blow by (rings) I would drain a 1/2 qt at least if you go over 6 qts....
Old Sep 30, 2005 | 10:09 AM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
overfilling oil can lead to contamination of the intake. Excessive oil will be diverted back into the intake manifold and burnt through the engine, causing sludge and carbon build up throughout the upper half of the motor. That's one reason why most manufacturers put on their dipsticks or in the manuals to "DO NO OVERFILL". Too much oil in the oil pan also means that the crankshaft will have to spin through the pool, robbing horsepower(although it may not be enough to feel).Get messy and dump some of it out, your engine will appreciate it. BTW, I AM a mechanic!
Old Sep 30, 2005 | 10:50 AM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
An extra 1/2-quart in a LS6 engine will not hurt a thing. The crank will not "spin thru the pool", nor will 1/2-quart cause "High pressure build up and blow-by".
The pan on a LS6 is very wide and was designed with "wings" specifically to keep the oil from doing any of those things.
I run between 6-1/2 and 7-1/2 quarts all the time.
Old Sep 30, 2005 | 11:08 AM
Wicked Weasel's Avatar
Wicked Weasel
St. Jude Donor '05-'08
Reading is fundalmental
At the track I put in an additional 1/2 quart before racing, but I usually burn it during a full day of laps.
regular driving I never go above the fill line (which is close to 7 quarts with the filter change). Not sure if it will do damage or not, but if you have the ability to drain some off why not do that?
I also heard that 1/2 way between the lines is full. Not sure if that is right or not.
why can't they make it easy. Bottom line add 1 quart - top line full.
Old Sep 30, 2005 | 01:00 PM
6 speed Sid's Avatar
6 speed Sid
The C5 has the most difficult to read stick on any vehicle I ever had. Also, there seems to be a lot of different opinions about what is full. If I go by the stick, it takes right at 7 qts to reach what I consider to be the full line, so 7 qts is what I use. ( That's with the rear elevated for a full drain).
Old Sep 30, 2005 | 01:12 PM
3 Z06ZR1's Avatar
3 Z06ZR1
Full to the top hole, when cold. I check when cold. Shows what is full and no case half way up.
Old Sep 30, 2005 | 01:52 PM
itsmeek's Avatar
itsmeek
no offense but this doesn't seem to be the best of advise. he'll damage his rings if he has that much more oil then he should in there.
Old Sep 30, 2005 | 04:29 PM
c3andc5's Avatar
c3andc5
There are some good replies here advising not to overfill your crank case. The only reason to ever have more then 6.5 qts in your vette is if you are racing. Trust your Owner's Manual. Drain that extra quart you put in.
Old Sep 30, 2005 | 05:17 PM
Beezvette's Avatar
Beezvette
Makes sense to me. In my vehicle that takes 7 quarts 12 oz.
Old Sep 30, 2005 | 07:02 PM
ndirishr1's Avatar
ndirishr1
I see you have lots of good advice here except most of it is different so it can all be right! Best thing I saw was read your owners manual!
Old Sep 30, 2005 | 11:16 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Default Reading oil stick
Please explain how this happens.
Old Oct 1, 2005 | 04:36 AM
c3andc5's Avatar
c3andc5
Adding too much oil can overfill the crankcase. As the crankshaft spins around, it can whip the oil into foam if the level is too high. This, in turn, can cause a drop in oil pressure and loss of lubrication to critical engine parts. Also, too much oil may cause leaks as the extra oil is forced past seals and gaskets, sometimes referred to as "blow by".
Old Oct 1, 2005 | 07:46 AM
davekp78's Avatar
davekp78
Maybe........
But my question was about the "damage the rings" part.
Old Oct 1, 2005 | 08:00 AM
exile's Avatar
exile
I think you might infer that
was the answer to your
, as well as other equally critical parts...............
To Reading Oil Stick...??
Old Oct 1, 2005 | 08:33 AM
mike348's Avatar
mike348
You can cross sand the end of the stick with 320 grit sand paper.It will be easier to read with new oil.
mike348's Avatar
mike348
Old Oct 1, 2005 | 10:41 AM
nmbsun's Avatar
nmbsun
The manual says 6.5 qts. I drained my vette at a downward angle to make sure to get all the oil out. I even let it drain for about an hour. When I put the new filter and filled it with 6.5 qts. the stick did not come up to full. I called every Chevy service dept. around and none said they had this problem. Thing of it is though is that when the dealership drains oil it does not get the rear end high so as to drain all the oil, so I assume if you dont raise the rear end higher then 6.5 would fill it too the fill line. If you do raise the rear to get all the oil out it will take 7 qts to fill it to the fill mark on the stick. At least that is what mine takes...
