Speedometer Cluster
Old Sep 30, 2005 | 01:13 PM
wetwilley99's Avatar
wetwilley99
2nd Gear
Default Speedometer Cluster
has anyone ever removed the instructment cluster on a 2004 vetter? i want to customize my speedometer face. if you have contact me and let me know what you had to do.
thanks
gary
Old Sep 30, 2005 | 01:44 PM
Mad_Maxxx's Avatar
Mad_Maxxx
Cruise-In VII Veteran
thanks
gary
Yes, it's not too hard for a novice mechanic, there is a post around here with instructions, I'll see if I can find it later on. You'll need a 7 mm, 10, and 14 mm sockets, ratchet, screwdrivers, pliers, and torx bit(cant remember the size off the top of my head). The shift ****, center console, lower dash padding will need to be removed.Just be careful not to lay the cluster face down for a lenghty period, it'll affect the backlighting(black lights).
Old Sep 30, 2005 | 02:31 PM
JCGRCYA's Avatar
JCGRCYA
St. Jude Donor '06
Check out VE's website for some very good, detailed instructions.
http://www.vetteessentials.com/instr...zel_howto.html
To Speedometer Cluster
