K & N Air Filter Install Help
Old Oct 3, 2005 | 07:05 PM
DylanFan's Avatar
DylanFan
Default K & N Air Filter Install Help
At Effingham I bought a dual cone K&N air intake. The instructions seem a little vague to me. They do not say anything about removing the power duct between the Mass Air Flow Sensor and the Throttle-Body. It has an ear on each side held on with some sort of plastic rivit or something. I am afraid that if I pry up on those I will break something. It looks like the power duct needs to be removed in order to get the stock air box out. Any help would be appreciated. Had a B&B twin tip Bullet system put on and it sounds great!
Steve
Old Oct 3, 2005 | 07:23 PM
Bandit1's Avatar
Bandit1
Steve--They're rubber. Lift the tab as push the rubber grommets through and they will release. Did when I switched mine over the K&Ns.
Good luck.
Old Oct 4, 2005 | 03:54 PM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Good luck.
To K & N Air Filter Install Help
