Royal Purple ATF?
Old Oct 4, 2005 | 11:08 AM
AndrewZ's Avatar
AndrewZ
Default Royal Purple ATF?
I have some royal purple atf fluid in my garage and was thinking of using it in my ZO6's 6 speed..
Has anyone used royal purple in thier vette?
How did you like it?
Just wanted to get some opinions..
Any other more highly recommended brands??
Thanks and
Old Oct 4, 2005 | 03:12 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I've had Royal Purple Max-ATF in my 6 speed coupe's trans for 3500 miles now. Runs fine... Also have RP Max-Gear in the rear....
Old Oct 4, 2005 | 03:16 PM
LRD VDR's Avatar
LRD VDR
RP
Shahram
Old Oct 4, 2005 | 04:39 PM
kg54trains's Avatar
kg54trains
Default Rp-atf
My 98 coupe is automatic and the car does shift better with the fluid. Smooth and quick.
Old Oct 4, 2005 | 04:56 PM
FKING1's Avatar
FKING1
Have Redline D4ATF in my 00 M6 for several years. It is about the same thing as RP.
Fred
Old Oct 4, 2005 | 08:02 PM
fotoboy's Avatar
fotoboy
just put Royal Purple syncro mesh in my m6 1-2 same 2-3 and 3-4 shift smoother and faster ( right where I need it for Drag racing) sythetic can hold up better the the other stuff that GM recomends. Least thats what the guys at GM told me
Old Oct 5, 2005 | 09:59 AM
AndrewZ's Avatar
AndrewZ
Thanks for the reply's guys...
Old Oct 5, 2005 | 10:00 AM
AndrewZ's Avatar
AndrewZ
How many bottles did you use in your diff?
Old Oct 5, 2005 | 02:13 PM
Glennm27's Avatar
Glennm27
If I remember correctly it was just short of 2 and I did add the little bottle of GM additive
Old Oct 5, 2005 | 05:18 PM
drbenne's Avatar
drbenne
I have used royal purple synchromax in my '01 Z06 and have had some high tranny temps at the end of the 30 minute runns with the SCCA and I have had no problems with the transmission or with shifting.
I use the royal purlple Max Gear for the diff and was told by royal purple that the additive was not necessary.
Old Oct 12, 2005 | 09:29 AM
Iceman_K's Avatar
Iceman_K
I put Royal Purple Syncromax in my manual tranny 1 week ago. Now it sounds like the tranny is going to fly apart. It is making alot of metal on metal clanking noises. This weekend I'm going to switch back to Dextron III to see if that helps. It could be a coincidence. I will send out an update after I do the work.
Old Oct 12, 2005 | 10:06 AM
Glennm27's Avatar
Glennm27
RP Max-ATF is Dexron III
Old Oct 12, 2005 | 10:53 AM
RoHo's Avatar
RoHo
I to am using Royal Purple Syncro - Max in my tranny, it never shifted so smooth, also using RP75-90 in the rear end but I did add the GM posie fluid.
Great stuff, a lot of guys Autocrossing is what turned me on to it.
To Royal Purple ATF?
