C5 Fuel Gauge
I agree with Shylor: Do try switching over to Chevron Premium. And, insert a bottle of the Techron II fuel system cleaner additive to your full tank of gas. It appears that the integrated C5 fuel pump assembly units are very sensitive to some of the sulphur deposits that may accumulate over time when using other brands and grades of gasoline. This build up on the fuel sensor will contribute to the erratic fuel gauge reading symptomology experienced by many C5 owners. The brand of gasoline that seems to be less conducive to this problematic issue is the Chevron gasoline. In my own experience, if I use Arco or Shell, I will get erratic fuel gauge readings. Eventually, I did have the passenger side fuel pump assembly replaced, and, the PC reflashed at the Dealership. However, when I started using the Shell or Arco (these are the fuel stations closest to me), the gauge would act up again. So, I have stayed with the Chevron ever since with no more erratic reading. Also, I now regularly add the Techron II fuel system cleaner at every tune up interval. Lastly, if you have over 30K, you may look into also changing your fuel filter. Good luck to you.
This is a common problem with lots of prior posts.
There are two likely culprits....
Sulfur deposits on the fuel level sensing unit caused by use of gas with high sulfur levels ( or low detergent levels)
1. Several tanks of good quality fuel might help see www.toptierfuel.com
2. Quicker results are likely from using a fuel system cleaning additive like
Chevron techron or Chemtool B-12 ( Walmart carries both)
It might take two to three tankfulls using this method before you can tell if it worked (based on previous posts)
If that does not do it the next trick is to look for corrosion on the ground connection to the sending unit. I know that I've seen some posts with photos on where to find it.
Finally others report that they have had to replace the faulty sending unit. there are alos posts on how to do that.
I like to start with the simple and work to the more difficult/expensive
That why I listed the way I did.
http://forums.corvetteforum.com/show...nds&forum_id=1
I was having the same problem intermittently and when I started using Chevron (from the same station) it has gone away. Knock knock knock! (knocking on wood!
http://forums.corvetteforum.com/show....php?t=1117236
